The pheonix rises (post the thief mmmm) - Page 4
Page 4 of 14 First 12345678 ... Last
Results 76 to 100 of 339
Like Tree143Likes
Thread: The pheonix rises (post the thief mmmm)
  1. #76
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,029
    Nice work Matt, you've certainly been busy!
  2. #77
    1,544
    Are you shortning the Gti6 manifold?
    Yes, also cutting out the resonator and patching it up also docking the end where it wraps the power steering pump, moving it back 2.5 cm.
    307 HDi wagon
    407 HDi wagon
  3. #78
    1,544
    The gear stick is unbelievable with brass bushes and new linkages plus rebuilt box, it is clinical in operation does not have to move much and a definitive pattern., this will be the best thing to try out for real. Big thanks to Adrian W.
    renn_205 likes this.
    307 HDi wagon
    407 HDi wagon
  4. #79
    Oct 2003
    609
    Quote Originally Posted by Matthew View Post
    Can you not shorten it and keep the resonator?
  5. #80
    1,544
    Would like to but the plan is to make it like your trumpets, then when time and money permit, get a shortened radiator and a full manifold (with air con), expensive but practical. The big issue with resonator is the shortening brings it back towards the head interfering with everything underneath, oil pipes etc
    307 HDi wagon
    407 HDi wagon
  6. #81
    1,544
    The pheonix rises (post the thief mmmm)-imag0611.jpg\
    Painted the 306 brake booster (a little movement in the top of the firewall permits fitment) bright red, new speedo cable, heater hose clamp on firewall, refit booster later this afternoon with two washer to tilt it up and silicon to seal it.,This was my Friday night experiment and it will give good brakes with the larger master cylinder.
    Of course found another bit stolen, the fuel sender, a trip to jr20516V and an Si being scrapped fixed that.
    307 HDi wagon
    407 HDi wagon
  7. #82
    1,544
    20 litres of unleaded, plumbed the pump, it went bang on turn of the key but pump stopped immediately, locked ECU maybe but it was bought as definitely unlocked. Anyway needs an exhaust system way too loud.
    Big thanks to Scott for showing the way on wiring and fault finding, lots learnt.
    Demannu, CEyssens and FIVEDOOR like this.
    307 HDi wagon
    407 HDi wagon
  8. #83
    Jan 2016
    Berwick VIC AUS
    1,029
    Default The pheonix rises (post the thief mmmm)
    I always enjoy starting an engine for the first time.. That must have been satisfying Matt
  9. #84
    1,544
    Indeed it is, Scott and I debugged it tonight, its the fuel delivery, most likely old filter, ECU is definitively unlocked, it continued to give spark and injectors with fuel pump hot wired.
    Doubt over the 6mm fuel lines if they are big enough, but a test on flow next weekend will tell us this. Most likely it will be running next weekend.
    Happier days!
    No muffler so must be done during the day. Almost antisocial.
    stew likes this.
    307 HDi wagon
    407 HDi wagon
  10. #85
    1,544
    It runs, noisey GTI6 in my local area, off to get a muffler, will copy Huw's work.
    Having a beer to celebrate.
    FU Magic you lying thieving piece of sh1t if I ever catch you its your testes for diner for you.
    307 HDi wagon
    407 HDi wagon
  11. #86
    Fellow Frogger! renn_205's Avatar
    Apr 2003
    Bondi Beach, Sydney
    221
    Congrats! Enjoy the well deserved beverage!
    Renn
    Peugeot 205 s16
    Megane RS 225 Cup
    Renn
    Peugeot 205 s16
    Megane RS 225 Cup
  12. #87
    1000+ Posts Richard W's Avatar
    May 2012
    1,323
    Congratulations Matthew - a real achievement. Any photos?
  13. #88
    1,544
    Thanks gents, a 45 mB video but its too big to upload, what a noise! Important safety tip, don't use RFY injectors in an RFS engoine, not compatible, or so it seems. Might have just been dirty / gummed but they did pulse but engine would not fire, suspect unhappy ECU.
    307 HDi wagon
    407 HDi wagon
  14. #89
    7,363
    What's an RFY?
  15. #90
    1,544
    xsi 306 xu10j4r much the same, or am I mistaken?
    307 HDi wagon
    407 HDi wagon
  16. #91
    Jul 2004
    799
    RFY/RFT is s16 and 405 mi s2.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
  17. #92
    7,363
    I can't recall exactly but isn't it 193 cc vrs 270cc?
  18. #93
    Oct 2003
    609
    Those Magneti Marelli ECU's are fussy about injectors. Cam85 found that the 1AP.10 ECU from the Xsara won't run properly with 306 1AP ECU injectors.
  19. #94
    Jan 2016
    Berwick VIC AUS
    1,029
    Happy days Matt!
  20. #95
    1,544
    Thanks, now onto the myriad of small things to be done, idle is first which means inlet wiring plumbing rad and air con, get the engine bay together, get an exhaust and finally the dash and then rego!.
    Silly me it was RFV injectors, 130 HP motor.
    307 HDi wagon
    407 HDi wagon
  21. #96
    1,544
    Dash repairs continue, this is to stop the squeeks and repair the damage the prick did. Getting very close top putting it back in, its nice and solid now and does not make noises as it moves, I hope its not too rigid.
    Inlet being modified and fitted this weekend and it all comes together, radiator, fluids and hopefully an idling engine!
    Kenfuego likes this.
    307 HDi wagon
    407 HDi wagon
  22. #97
    1,544
    Dash is in wow, no squeeks, unique installation and repairs! will come out again to figure out the little top middle bolt (small 10mm) that completes it fitment.
    Pictures to follow....
    307 HDi wagon
    407 HDi wagon
  23. #98
    1,544
    Where's Craig, no pizza on my dash!
    Jealous yet?
    307 HDi wagon
    407 HDi wagon
  24. #99
    Jan 2016
    Berwick VIC AUS
    1,029
    Mate, you deserve a decent dash!!! Nice work
    Mine is just crap.
  25. #100
    Dec 2002
    2,498
    Like a bought one.
    GreenBlood likes this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
