Richard's 205 GTi6 project - Page 8
Page 8 of 10 First ... 45678910 Last
Results 176 to 200 of 232
Like Tree72Likes
Thread: Richard's 205 GTi6 project
  1. #176
    Fellow Frogger! renn_205's Avatar
    Apr 2003
    Bondi Beach, Sydney
    221
    Must be great to have her rolling again! Great perseverance and amazing work by Huw!
    Renn
    Peugeot 205 s16
    Megane RS 225 Cup
  2. #177
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    832
    309 rear beam? Looks nice and wide from the rear.
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
  3. #178
    1000+ Posts Richard W's Avatar
    May 2012
    1,336
    Quote Originally Posted by SilverGTi_6 View Post
    Yes - 309 beam at the back and 309 control arms at the front.
    SilverGTi_6 and renn_205 like this.
  4. #179
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,042
    Wonderful looking GTI Richard
  5. #180
    1000+ Posts Isis's Avatar
    1,100
    Nice colour and wide stance, subtle badging too.
    renn_205 likes this.
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
  6. #181
    May 2012
    1,336
    Quote Originally Posted by James504 View Post
    I never got the standard M.M ICV to work either with haltech's.
    Luckily haltech market a ICV and housing. Other options are to use an earlier style Bosch stepper motor or use something Japanese.
    Hi James. Huw has not been able to get the Haltech idle controller to work properly - says it is smaller than the Pug original and does not have enough range? You seem to have been here before - are you able to expand on your suggestions please?
    Do I have to resort to something like this, which seems to be a cruder 'on/off' set-up? HT-020308 Idle Air Control Valve ? Bosch BAC/PWM 2 port, 2 pin - Idle Control - ECU Outputs and Ignition Systems
    Richard
  7. #182
    Fellow Frogger! patpug's Avatar
    614
    Gday Rich,
    I haven't had the ICV working on my car for about 5 years. It doesn't idle smoothly for about a minute after cold start but after that smooth as the proverbial. Has Huw adjusted your idle timing/mixtures in the Haltech?
    Might the idle issue be another side effect of bigger cams?
    Looking forward to a drive swap! I hadn't driven mine for a couple of months for one reason or another, had a drive last weekend and it's a little monster.
    Pat
    MayheM likes this.
    205 gti-6
    205 track car build in progress http://www.aussiefrogs.com/forum/res...-race-car.html
  8. #183
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,381
    Quote Originally Posted by patpug View Post
    gday rich,
    i haven't had the icv working on my car for about 5 years. It doesn't idle smoothly for about a minute after cold start but after that smooth as the proverbial.
    Pat
    "ditto"
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
  9. #184
    7,396
    Maybe try an XU10J4 ICV, which uses BAC/BAC slave connectivity?
  10. #185
    May 2012
    1,336
    Gday Rich,
    Pat
    Thanks Pat. Looking forward to swapping cars for a drive to maybe help work out what to do with mine.
    I don't think the cams are the problem with the idle. Once the car is warm it idles sweetly. However, when it is cold it needs to be held above 2500rpm for a few minutes until it will idle. Huw has spent about 30 hours trying to set up the Haltech ICV but hasn't been able to make it work well. I'm wondering if it is just fundamentally undersized.
  11. #186
    May 2012
    1,336
    Thanks Peter. So is BAC/BAC different to the J4RS item such that the Haltech might be able to drive it? I'm going to have to sit down to do some research and understand more about these things.
  12. #187
    May 2012
    1,336
    Pretty pedigree (VC205's car) came out to play with my mongrel this morning for a bit of a run through the Royal. Interesting now to drive my car back to back with a perfect original car.
    I managed to get brake fade on the downhill run into Garie Beach so the Greenstuff brake pads will need to be upgraded.
    The car goes to Phil Armour tomorrow to see if he can sort out the cold running and see how many horses he can find for me!
  13. #188
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,290
    Looking forward to seeing the results after tune.
    Wildy55 likes this.
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
  14. #189
    7,396
    Dare I say 109kW ATW?
  15. #190
    May 2012
    1,336
    Isn't that what Pat's car made? Was that on Phil's dyno as well?
    With your stage 2 cams instead of stage 1, forged pistons with 11.5:1 and a bit more work to the head than Pat's car I'm probably hoping it will make a touch more. But probably more important is finding a bit more in the midrange than its got now and getting it to be less of a pig when cold.
    If my car makes the same power as Pat's car on stage 1 cams I guess I'd be better off swapping back to stage 1 cams too and having the fatter midrange. Should they work well with those pistons?
    Time will tell. Phil has another project ahead of mine so may not have the results for another week or so.
  16. #191
    7,396
    True. I had forgotten your spec. Pat made 108, thus 1 more seemed appropriate.
  17. #192
    May 2012
    1,336
    I'll also have a cold air intake. Might be interesting to test with and without that to see what difference it makes.
    Sent from my iPad using Tapatalk
  18. #193
    May 2012
    1,336
    Quote Originally Posted by Richard W View Post
    Couple of photos from this morning
    Richard's 205 GTi6 project-beauty-mongrel-1.jpgRichard's 205 GTi6 project-beauty-mongrel-2.jpg
  19. #194
    May 2012
    1,336
    I just realised I will be on a different dyno to Pat's tune so won't really be able to compare power result directly except against Parry and anyone else who has used Phil to tune their car?
  20. #195
    1,100
    Ride height looks good
  21. #196
    Fellow Frogger! chez00's Avatar
    567
    Lovely car.With 11.1, PeterT stage 1 inlet cam, minor head work I made 108.4kw at 6600. I sorted out a breakdown we were having at higher RPM since (crank angle sensor getting feedback from coils), so perhaps 112 or so.
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
  22. #197
    May 2012
    1,336
    Default Richard's 205 GTi6 project
    So here's the dyno graph - 149hp atw, or 111Kw. I'm surprised at just how linear the graph is - torque curve is almost flat! I haven't collected the car yet so don't know if it feels any different to drive, but it doesn't look like midrange has changed much.
  23. #198
    7,396
    Nice. Mine is flat like that too, with a very linear power delivery. It's a great build.
  24. #199
    May 2012
    1,336
    I spent some time this weekend cleaning the car for FCD next weekend. Thought I would take some photos before it gets dirty again!
    Richard's 205 GTi6 project-img_0288.jpgRichard's 205 GTi6 project-img_0291.jpgRichard's 205 GTi6 project-img_0293.jpgRichard's 205 GTi6 project-img_0295.jpgRichard's 205 GTi6 project-img_0299.jpgRichard's 205 GTi6 project-img_0302.jpgRichard's 205 GTi6 project-img_0303.jpgRichard's 205 GTi6 project-img_0305.jpgRichard's 205 GTi6 project-img_0290.jpg
  25. #200
    1,100
    Rich this looks excellent. I love the general colour scheme, which is a perfect display of tempered enthusiasm. Such a cheeky and subtle little machine. I like how the wheel stitching matches the seats, making it all look integrated and resolved. The seats look comfortable, are they still on the oem runners and standard height?
