Turbo 205 conversion build
Results 1 to 15 of 15
Like Tree3Likes
  • 3 Post By jr20516v
Thread: Turbo 205 conversion build
    brisbane
    2,882
    Default Turbo 205 conversion build
    Finally getting near to the end of inserting the XU10J2TE motor from Xantia into series 1.5 205. With the battery removed to the rear of the car it has freed up alot of space in the bay which is dearly needed with turbo motors.
    Really happy also that i have nearly 15cms between radiator and motor.
    Done thus far....
    1. new suspension f & R. dampers, droplinks , donuts etc etc.
    2 Replaced hubs, installed 266mm rotors and calipers with new pads from a 306 16v XU7
    3. new re routed fuel lines- complete car.
    4. mi16 gearbox rebuild with Quaffe LSD [gear ratios changed to suit turbo app ]
    5. new mi16 clutch fitted.
    6. dummy up intercooler and brand new rad.
    7. remove and clean out fuel tank.
    More updates soon. see attached pic.
    JR
    Attached Thumbnails Attached Thumbnails Turbo 205 conversion build-pig2-engine-bay.jpg
    renault12, graham66 and frog like this.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. Opel OPC
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Looks great so far JR! Is that Xantia engine originally have a stock turbo? love what you've done. keep the pics coming
    Julian
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,300
    Lookin good Jr! Good to see your posting pics! Great job, glad you've stuck with it. What did you do for a master cylinder in the end(or space for it!)
    Cam
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    Armidale
    2,279
    Quote Originally Posted by pug-life View Post
    Julian
    Yes the XU10J2TE is the PSA 8-valve 2 litre motor with factory turbo. Was fitted to Xantias, XMs, 406s and 605s. Only the Xantia Turbo CT was sold here (I have one ).
    JR, my XU10J2TE has a blown headgasket, so might be a chance to 'improve' the engine. Have you rebuilt yours - if so have you modified anything?
    Alec
    Nov 2003
    Bondi
    3,300
    You can fit an early 205 gti camshaft. Or have one reground by PeterT. A little more work but also fitting a better inlet manifold can help. The 205 gti manifold works. Not sure about all the sensors required to make it work an how they would fit onto that manifold. I'm sure it would not be hard. You can also up the boost a little by using a manual controller. The standard computer can run up to 1 bar/14 psi. That will net you a nice gain I would think!!
    Cam
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    7,415
    DKZ cam, electronic boost controller and a decent ECU is needed to get the best out of it.
    brisbane
    2,882
    i agree.... the items that really hold this motor back is the shocker of an exhaust manifold and little space for a bigger turbo. All costing mega $$ to change and then there is the aftermarket ECU which would really be the bees knees....however i am going just for a mild setup so keeping it mainly stock with just the 1bar boost upgrade. The good thing about this turbo assembly is it has basically no lag so will be interesting in a light car such as the 205 rather than the luxo barges it normally lives in.
    Been tying up loose ends on it today and just found that the swaybar is 17mm.....WTF !!! More chasing around for a correct one:}
    jr20516v
    Now:
    brisbane
    2,882
    Cam
    Thx Cam. Mmmmm....the BMC is a little outstanding problem yet to be done :{ If i can get a smaller booster that would be the dogs bollocks and do the trick me thinks. Have you heard of any smaller boosters being used and if so which one [a Datto 180b one has been mentioned but they are rarer than 205's LOL
    jr20516v
    Now:
    brisbane
    2,882
    errr....how does one post up more pics on a "reply thread"?
    jr20516v
    Now:
    18,455
    "Go advanced" -down the bottom
    "Manage Attachments"
    Then you are in upload manager which should be familiar
    brisbane
    2,882
    Default Pic of ally fuel lines throughout
    Finally got a pic of new fuel lines....more pics to come. Chasing new brake lines now as mine are on the way out.
    Attached Thumbnails Attached Thumbnails Turbo 205 conversion build-pb220391.jpg
    jr20516v
    Now:
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    492
    That looks great, man.
    brisbane
    2,882
    Thx Stew :}
    Another update pic attached.
    Attached Thumbnails Attached Thumbnails Turbo 205 conversion build-pb220392.jpg
    jr20516v
    Now:
    brisbane
    2,882
    Today update....did new brake lines, sway bar bushes, drop links and extended some sensor wires on the loom so as to fit the ECU well away from the turbo area. The Ecu is going where the battery was as it is a major job to extend the loom into the cars interior.
    The ECU will have its own box and maybe fitting a 12v fan from a PC to keep it coolish.
    jr20516v
    Now:
    brisbane
    2,882
    Getting near to finish the mechanical side of it....this week...battery allocated to boot. Got a brand new battery from a friend that isnt on the market as yet...huge cranking power...happy :}
    Pic of complete new stainless straight through system going on.
    Thats it for now..
    Attached Thumbnails Attached Thumbnails Turbo 205 conversion build-pc110403.jpg
    jr20516v
    Now:
