nuts and bolts
Results 1 to 18 of 18
Thread: nuts and bolts
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    563
    Default nuts and bolts
    Can anyone tell me where I might get a selection of citroen (genuine or not) nuts and bolts to replace those that are missing on my SM. They are mainly small ones on the under tray panels, but it is always handy to have a jar of assorted sizes handy.
    cheers Tony
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    go raid a wrecked SM and you will have the poper nuts & bolts
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    castlemaine
    503
    Quote Originally Posted by deesse View Post
    cheers Tony
    Tony,
    fasteners to suit are available from a number of European suppliers, but I suggest you try www.citroenclassics.co.uk/‎.
    If you dont require them to be genuine Citroen items then any good fastener store could supply. The undertray is held on by 5mm x 0.8mm pitch setscrews about 20mm long.
    roger
    Los Angeles, CA USA
    1,955
    You jest. When we liquidated te garage we sold shovel scoops of random bolts, nuts and washers for 30 bucks US. Sold ' em all too.
    Via the aussiefrogs App
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    Quote Originally Posted by daffyduck View Post
    Actually I was being serious. When I have wrecked many a R12 I have removed every nut, bolt, fastener that was attached to the shell and stored them in tins for future use.
    All these tins of nuts and bolts has been very handy over the past 30 years.
    Regards Col
    1973 Alpine A110
    16,295
    I do that too.... I still seem to have barely any spare fasteners. The problem is a lot of cars have missing or trashed fasteners, so you rapidly use up all your spares. Nuts are always the hardest to find. There is plenty of fasteners on parts cars, but most of them dont' have a nut on the other end (as they screw "into" something).
    M5 x 0.8 should be easy to find. They will be readily available from local "bolts and fasteners" types stores I imagine. M5 x 0.75 (early DS/ID) is much harder to find
    Los Angeles, CA USA
    1,955
    I was referring to the chance of finding an SM parts car down under.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    I see, well maybe raid another Citroen of that era.
    Regards Col
    1973 Alpine A110
    castlemaine
    503
    M4 x 0.7 (early DS) are even harder to find.
    roger
    Sep 2003
    North Parramatta
    3,986
    Last time I looked under the bonnet of your CX (possibly in Tassie) there were plenty of spare fasteners along the tops of both front guards. Have you used them all?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Sep 2003
    North Parramatta
    3,986
    Simon
    CitroŽn Tragic UFO's Avatar
    9,647
    Quote Originally Posted by SLC206 View Post
    That was Cit In in McLaren Vale in 2009
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    M4 x 0.7 & M5 x 0.8 can be found on Ebay
    Regards Col
    1973 Alpine A110
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,248
    These are very much standard spec screws and/or bolts. Do they have 'something' Citroen different, such has spanner size...M4 is 7mm across the flats and 3mm In Hex Allen key, M5 is 8mm across the flats and 4mm In Hex Allen key. ALL quality suppliers will have them in various grades and material types. Confused as to why it seems to be so hard? Brendan.
    San Diego, California, USA
    3,495
    Quote Originally Posted by bluey504 View Post
    I think it isn't so much the fasteners are hard to find, but the exact style. A lot of Citroen-specific bolts have a double chevron (OMG- can you just imagine all your hardware with Shane's likeness on it??) stamped into the top, and what passes for a lock washer is a slightly cone-shaped 'flat' washer with serrations around the bolt hole. Almost everything is gold cad. You can fake a lot of the hidden stuff, but quite a lot of it is on display in some manner. Of course, being the anoraks- excuse me, pain in the *ss- that many Cit owners are, we gotta have the real stuff.
    16,295
    They'll still be there ..... They hold on the bits I haven't bothered to screw back on .... They obviously aren't required
    Dec 2010
    Melbourne Australia
    563
    Thanks men,
    I will consult with my local fastener shop with the sizes suggested.
    cheers Tony
    Dandenong Vic
    1,248
    Tony whilst you are unlikely to get fasteners with Shane's face imprinted in them. (Then again Ang might like to earn a few dollars 'smacking' Shane into a couple of hundred bolt heads...may even do it for free!) I'd recommend that you take a sample or two down; Cadmium plating 'Bad/Toxic', ZPG (Zinc Passivated Gold) Good. The lock washers as described by Hotrodelectric are what I'd call "electrical/mechanical contact washers". Used them for years whilst serving time at Schneider Electric building Ring Main Units. They came in metric sizes 3,4,5,6,8,10,12 and 16. May have been bigger but this range covered what was needed to be done. Looking at them they are a great thing as so long as you have a flat surface under the bolt head or nut the requirement for a flat washer is removed. Was common to use one at each end ie under nut and bolt if space was tight and 'I do NOT want to have this come apart' application was required. I may have said this previously, pretty sure I have, but I might see if I can chase up these critters....also have used them as S/Steel but they are a 'oncer' as they flatten out and that's it. Brendan.
