205 off the road again....
Results 1 to 25 of 27
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    Default 205 off the road again....
    So after being off the road for 2 months, I got the new clutch cable in and the retaining pin made up and installed. It then took two days for the passenger side drive shaft to explode. I was on my way to get my mother a birthday card and head over to the hospital to see my grand father when it happened so it came at a horrible time. Now the reason I think it's the drive shaft is the clutch still works it goes into gear and as soon as you disengage the clutch you can feel what feels like rocks rolling around in the inner cv boot. I have an SI sitting on my front lawn that's for parts and I'm hoping they fit? Does anyone know for sure? Peter T (the god of all information 205) can you help with info.
    cheers in advance guys.
    p.s need the car in two weeks, urgent help needed.
    7,415
    Yes my son. The Si shaft will fit if you have an early GTi with the smaller 1.6L hubs.
    394
    The GTI is 89 and the SI is a 91 I'm pretty sure. If I don't have the earlier hubs would it be logical to swap the SI hubs over with the SI drive shafts, so I can go for the 306 brake conversion later down the road?
    7,415
    If the hub nuts are "staked" then they're 1.6. If they have an "R" pin they are 1.9. Being '89 yours is most likely 1.6. Thus Si hubs would be a logical upgrade at the same time.
    NSW
    623
    Sure you havent blown the diff?
    Adrian Wuillemin
    9,107
    You mean if you DO have the earlier hubs?
    You will need to swap to the 306 brakes at the same time you fit the Si hubs.
    Graham
    Quote Originally Posted by le frogg 205 View Post
    394
    I really hope I haven't blown the diff. What would more likely go? A diff or a shaft?
    NSW
    623
    Probably the diff
    Adrian Wuillemin
    394
    Ok so I just got under it after a long day of collage and as I wipe the fluid of the diff casing I put my finger through the top of the casing. Defiantly diff.
    7,415
    Lots of bananas.
    394
    What?
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,820
    Banana peels are soft and fiberous and help to hide any nasty sounds while the prospective buyer takes the car for test drive. May not last long enough for the buyer to get it home. Additional saw dust can also help.
    394
    Sneeky lil devils. I need a new box, what have people got in order of complete boxes?
    7,415
    Haven't you got an Si in your front yard? Remove the gearbox from that and take it to Adrian, along with your blown box.
    394
    SI and GTI are the same? I've got a box lined up. But I approx size a weight for freight? Does Adrian rebuild boxes? If so what's the pricing on that?
    9,107
    Si is a BE3, an improvement over the BE1. You would need to change the clutch cable or modify slightly and simply don't use the reverse lock out cable.
    The Si box has wider ratios but the same final drive as the GTi.
    Adrian would put your original BE1 gears into the BE3.
    Graham
    NSW
    623
    Si ratios would be hopeless.
    I can give the gearbox you are buying a rebuild or mix and match boxes to give you the best parts.
    email me - [email protected] for pricing
    You will need to lengthen the clutch cable if you go from a BE1 to BE3, i have the extension pieces as well
    Adrian Wuillemin
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,267
    I have a good series one Mi16 be1
    Via the aussiefrogs App
    406 D8 V6 manual
    394
    What are the differences in ratios with th MI boxes? Are they better.
    9,107
    Wider ratios except for 1st to second which is closer but they do have a 4.3 final drive instead of 3.9 so still a good box as they will pull well in second gear.
    Graham
    NSW
    623
    Look at Taylor engineering website for ratios
    Adrian Wuillemin
    394
    ok so I am hoping I get the gear box by Sunday arvo or Monday morning. what seals/washers/miscellaneous should I replace before I put the new box on?
    Sunbury, VIC
    2,267
    While it's out it's a good idea to do the clutch and rear main seal. Might even be worth looking into lightening the flywheel.
    406 D8 V6 manual
    9,107
    Yes, you will be amazed at how light the clutch pedal is with a new clutch.
    Quote Originally Posted by cav91 View Post
    394
    the clutch is actually great on it, id love the box to no leak so are there any seals that people don't really bother to change when they can.
