Christian's R10S - Page 9
Page 9 of 10 First ... 5678910 Last
Results 201 to 225 of 237
Like Tree113Likes
Thread: Christian's R10S
  1. #201
    1000+ Posts Frans's Avatar
    Auckland
    1,423
    Frans, does the bolt go through that rubber or is it the type with a stud on either side bonded to the rubber?
    Sent from my Nexus 6P using aussiefrogs mobile app
    Studs bonded at either. Proper universal mounting for sound isolation.
    Brett, I appreciate your dedication to originality but after a while they will sit on the safety overrider stops permanently.
    Frans.
    JohnW likes this.
    Old enough to know better
    Young enough to do it anyway.
  2. #202
    Oct 2012
    600
    Rear engine mounts completed. Just needs a little more tidying and a coat of paint.
    renault8&10, JohnW, J-man and 1 others like this.
  3. #203
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Like your work Christian, just a quick question before you pain that cross member. What are doing for an exhaust system? The reason I ask is that the Alpine boys put the muffler across the back of the car and it is supported off that cross member and the exhaust moves with the engine. Just save you painting it twice if you was going down that route.
    Dano and J-man like this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  4. #204
    Oct 2012
    600
    I hadn't really given too much thought to what was going to hold the muffler up, hanging it off the cross member is a good idea but it is going to end up canter levered a bit as the back of the car is some distance out the back on 10's. I'll have to run a cat as well being a modern engine.
  5. #205
    622
    Sorry Chris, but I must have missed it earlier, but what modern engine are you planning to run in the R10?
  6. #206
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,564
    Christian,
    Exhaust mount. See #54 http://www.aussiefrogs.com/forum/res...110-v85-3.html
    A late Range/Land Rover rear mount, welded to a band around a stainless box. I have it on two other cars and it works very well.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
  7. #207
    Oct 2012
    600
    Quote Originally Posted by R8 Dream View Post
    It's a K4M from a Clio.
  8. #208
    Oct 2012
    600
    Who doesn't like a nice smooth rear end. The corners were the hard bit. Good use of my latest sheet metal tool, a shrinker/stretcher.
    On another note I'm looking at the possibility to a 4 stud conversion. Not that I haven't dropped money on my current brake setup which I could hopefully reuse. Mitsubishi Lancer hubs for the front, or something I can make work, sleeve the stub axles to accept larger bearings. Rears would need to be custom, the expensive part, but not in bulk. I haven't dropped the projected $2.5k on wheels yet, so this may work out cheaper as 4x100 wheels are plentiful. More research and cad modelling required.
    bowie and LeMansTragic like this.
  9. #209
    Oct 2012
    600
    And the modern handbrake lever to go with the modern rear brakes.
    I also put a jog in the gear linkage shaft to I can hang the gear stick out further from the pivot to shorten the gear throw.
    bowie likes this.
  10. #210
    4,286
    More detail on the handbrake please. I’ll need something custom to run the cables around to pull from behind on the FIAT calipers.
    KB
  11. #211
    Oct 2012
    600
    Handbrake lever came from rally designs in the UK, part number RD6901. I was buying brake calipers at the same time. New ones even, from a mk4 golf. Only 38mm pistons but can run rotors upto 270mm. I'm aiming for for 265 ish.
    Handbrake cable is a wilwood, 330-9371.
    Black bracket is a nut plate I made that holds it down. You could just as easily just put nuts on the bottom. Had to drill some additional holes in the floor.
    One picture shows the cable stops under the floor, the other shows the new holes.
    I thought I get a comment about my 4 bolt hubs first.
  12. #212
    Oct 2012
    600
    A little CAD (cardboard aided design), fuel tank. Transferred the design to the other sort of CAD, comes out at just over 40 litres. Next step, get it quoted for manufacture, can't make this one myself, then take orders.
    To the point now I should stop making small changes and just send it to a panel beater to get it clean up and sprayed. I just really didn't want to do that until I'd finished drilling holes in it.
    J-man, FIVEDOOR, 27of85 and 1 others like this.
  13. #213
    Fellow Frogger! Gordini Pervert's Avatar
    Mar 2012
    Perth
    195
    Great build @c.lees... its going to be amazing!
    2 questions though
    >>why not use the Clio 2 litre twin cam 16 valve from the Clio 182? (so cheap now!!)
    >>and how will you handle all this power through the pissy 10 gear box?
    Keep up the excellent work!
    Sam
  14. #214
    Oct 2012
    600
    Quote Originally Posted by Gordini Pervert View Post
    2 questions though
    Sam
    I wasn't sure if the gearbox would take the power of an F4R but I have found out that it is a conversation that is done in France. You use a R16 bell housing and an adaptor plate.
    In hindsight the flywheel issues may have been easier to solve. But it could be the same story, like the use of parts from cars that were never imported into Australia.
    My gearbox has R16 internals, should handle the K4M just fine, even it I do decide to put a turbo on it.
  15. #215
    Oct 2012
    600
    On another note. I've been fixing up some body work, I had fixed the drivers side head light housing but it looked to be holding the front guard out a little at the bottom. So I have remade the offending part. This time I had a shrinker so I could make it from one piece
    Now with this part in place the headlight hole is snug compared to the other side. The question is, are the two side meant to be the same, I ask as I wouldn't put it past the French to do something like this. Or does the guard need a little massage, it is possibly the only good panel on the car.
    New rear brake pictures to come.
  16. #216
    Oct 2012
    600
    Not a great deal of exciting work going on. I have done some work on the fish mouth panel.
    On striping the remaining paint I discovered one side was completely caved in. I knocked it back out with liberal application on heat and percussive force. I should have taken a before picture. Here is an after with some filling.
    Sent from my Nexus 6P using Tapatalk
    LeMansTragic, bowie and J-man like this.
  17. #217
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,255
    That be success body filler there.
    It's gonna be great
  18. #218
    Oct 2012
    600
    Yep, that's a lot of filler. There has been quite a bit of additional metal work on the front. Not sure which war this car was in, it was not straight. When I had it stripped they commented how much filler was on it, I now hope it's less.
    I've had to reattack it with a cut off wheel, welder and even an oxy torch. I cut a large piece our when I just couldn't get it the right shape, so I remade it.
    Now it's symmetrical. A little more filler will be required and a tap here and there to push down any high spots. The filler is no thicker then 3mm, much less then that for the majority of the panel.
    JohnW, bowie and J-man like this.
  19. #219
    Aug 2002
    3,255
    Ah man it will be worth it no doubt. And look! your filler is sticking to stuff, there must be metal under it
  20. #220
    Oct 2012
    600
    If your initial thought is "that's a lot of filler" then you'd be correct. I do believe it's less then what was on the car when I started. I have toyed with the idea of ditching the aluminium panel on the rear and smoothing out the bumps but it would involve getting it much smoother above the tail lights.
    One more small application of filler for the couple of remaining low spots, a quick skim with glazing filler and it should be ready for high build primer. The primer will need to be rolled on as I can't spray 2k at home.
    There is a little more to do the on the front then it's time to find a spray painter to give it some colour.
  21. #221
    4,286
    I think the panel finishes off the rear of the 10 though. Might look a bit odd without it?
    KB
  22. #222
    Aug 2002
    3,255
    Ah you are going to feel great when it gets some colour on it
  23. #223
    Oct 2012
    600
    Tiny amount of progress. I'm now happy with the gaps where the rear guards meet the C pillars, small and nice and even.
    In mounting the drivers side guard and sanding down the filler I've discovered another dent, obvious in the photo as I've sanded the panel to make it show up. This body is going to end up with about 10kg of filler on by the time I'm finished. They would be way to hard to try and pop out as they are pretty shallow.
    Moving onto the front guard I've decided to shave off the bumper mounts. In hindsight maybe I should have left them there, turned into a bit of a nightmare in terms of oil caning. The panel may not have been straight to start with, it's still not great but even the unmodified side oil cans a little. Needs a little more work to stiffen it up, the bumper mount would have added stiffness, although the oil caning is higher up the panel. I'd say the culprit is to much heat during welding. The vertical weld is a slit I cut to attempt to reduce the issue.
    If fibreglass panels were available for 10's then I'd just buy some.
    On the good side the rear panel is ready for glazing filler.
    Christian's R10S-1536476633686.jpgChristian's R10S-1536476656998.jpgChristian's R10S-1536476710914.jpg
  24. #224
    4,286
    Fibreglass panels aren’t always the bolt on and paint option they claim to be.
    I’m not aware of any suppliers but can’t say I’ve looked. My R8 ones came from mcracingsa.com from memory. I can’t see any mention of R10’s however.
    KB
  25. #225
    Oct 2012
    600
    There is possibly a reason this car will never be finished, besides the lack of time and far from straight metal work.
    If you're not happy with it, cut it off and make a new one. Those end panels weren't symmetrical anyway, it bugged me.
    The question is, do I just make the end bits, or the whole lower panel as one piece? I could do it in fibreglass, but that's a lot of work, make a positive, probably out of wood and foam, make negative mould, make actually panel.
