petrol tank cleaner
Results 1 to 8 of 8
    Oct 2003
    canberra
    870
    Default petrol tank cleaner
    Is there a proven product/ method, to loosen crud in old petrol tanks?
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    576
    Alpine,
    I used the POR15 kit on a crusty 504 Ti tank recently!
    You need to remove the tank and follow the instructions to the letter but its relatively simple. Let it 'dry' over a week or more to ensure the product goes 'off' before refitting. No more brown fuel filters at the back of the car after that.
    Ian.
    Wright ACT
    576
    Ahh, I reread your original post. Now to loosen the rusty cr&p in the tank for starters - Maybe POR15 Marine Clean and/or Metal Ready solution will do the trick.
    Try this link http://www.por15.com/FUEL-TANK-REPAI...ductinfo/FTRK/
    You can buy the POR15 gear at Auto Paint Supplies in Koala Court in Fyshwick.
    Ian.
    con
    con is offline
    sydney, nsw, australia
    522
    Quote Originally Posted by alpine View Post
    Colin,
    You need to put a quantity of gravel inside the tank and then strap the tank to a concrete mixer: Switch on the mixer for 15-30mins or until all the "krud" is loose.
    I think you get the general idea.
    con...
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,156
    Then how do you get all the gravel out???????
    Cheers Gerry
    719
    Hi Gerry,
    For what it's worth I've had two tanks professinally cleaned. They use an acid etch to remove all the rust in the tank. Very happy with the result.
    I'd avoid the internal coatings etc. as when they break down (and they will eventually) they become the problem...! Use something like "Fuel Doctor" to avoid the issues with moisture in the first place.
    Mark...
    bob
    bob is offline
    May 2001
    Skipton
    2,496
    G'day,
    so what's wrong with modern fuel ?
    When we changed from leaded all those years ago there was a couple of filter changes as the new stuff scoured the tank and lines......
    cheers,
    Bob
    129
    Default petrol tank cleaning
    hi all
    i thought it is about time to give the info how to clean old petrol tank,as i just did the one on my peugeot 203.
    dont bother with por 15 as it will pill off and make more problems,realy waste of money .i think it is $100 for the kit
    do it your self you need soloution of hydrochloric acid ,you can buy in pool shops but it is nasty in risky job and will have to be neutraliazed with soda bicarb .will be good for small tanks like motor bike .you can read about it by googling how to clean petrol tanks.
    the best way ,and yes you may have to spend some money is to go to radiator place .there is national one
    called natrad which dip your tank in caustic in it comes clean .it is $120 worth while . you will have to keep the tank full if you dont use the car too often.mine was more complicated
    as there was a lot of rubish inside and had to be opened from the top ,and a new mesh was soldered at the outlet pipe on the bottom of the tank.i must say it is well spent as i have no more problem of fuel line blocage.
    if you want more info you can always contact me
    cheers ron
