Koleos Hints, Tips, Problems
Page 1 of 35 1234511 ... Last
Results 1 to 25 of 869
Like Tree120Likes
Thread: Koleos Hints, Tips, Problems
    Oct 2005
    vic
    858
    Default Koleos Hints, Tips, Problems
    Righto let's start a Koleos subforum.
    Koleos problems posts here, Hints, tips etc.
    Oct 2005
    vic
    858
    Default Service reminder reset
    Using the trip computer scroll buttons - scroll display until distance to next service is seen.
    Press button AND HOLD until km to next service flashes.
    Short press scroll buttons up/down until desired next service distance is displayed.
    Once desired service interval is displayed - long press to set.
    This is described in the drivers handbook 1.51 Edition 07/2008
    Interesting to see that the book describes either 30 or 20,000 km service intervals.
    Service manual states 15k intervals.
    Nov 2002
    Yarrabilba, Queensland
    2,759
    I'd go with the lower service intervals myself.
    I do so with the Scenic as the amount of dust and crap in the air filter is enough to scare anyone at 10,000km.
    I know the books and all manuals from the EU and UK say longer, like the 30,000 you mentioned. Truly believe that maybe fine for their climatic conditions where they have much less dust and small particles in their atmosphere
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,359
    My former service agents repeatedly kept setting my "next service interval" at 10,000 km for my diesel Koleos. I read the handbook and quickly ascertained the method for changing the value. I'm happy with 15,000 km because these days it's about once a year.
    Oct 2005
    vic
    858
    Default Manual Gear-box oil specs
    Howdy,
    There's a little bit of feedback in the gear stick when changing 1-2 in the 6 speed box. Will change the box oil and see what happens. Read the books (and unless i am suffering from selective blindness) can't find the specs and change intervals for the gearbox.
    Anyone know?
    Oct 2005
    vic
    858
    Default Gearbox oil - FYI
    Gearbox oil
    ELF NFJ 75W80 (GL4+) you need 2L
    Rear Diff oil
    TRANSELF Universal FE80W90 (GL4 &5) you need 1L
    Oct 2005
    vic
    858
    Quote Originally Posted by Breitie View Post
    the thing makes an awful rattling racket, obviously until the oil has circulated.
    The original oil is Elf fully synthetic 5W-W40. Is that too thin? Would I be better off using 10W-40W
    Breitie,
    Obviously from the oil specs you have a petrol powered version.
    How long is the racket for?
    Just whilst starting or afterwards?
    Oil level correct?
    Fresh oil/filter?
    May need an oil pressure test?
    Unless you are in FAR north Queensland 5W40 is adequate.
    Magnatec will be inferior.
    Keep us informed.
    David
    Manly West, Brisbane
    394
    Hi David, thanks for your interest.
    My petrol Koleos is new, only ca 3000km on the dial. Oil level is good.
    Rattling noise lasts maybe one-two seconds upon cold start
    but sounds frightfully coarse and abrasive.
    Never heard that on my Scenic nor any previous car.
    5
    A rattle is a worry, my privelege has a whine but it ia the handbrake servo disconecting the handbrake for me, it may be the same for you.
    Feb 2011
    Perth
    21
    Gas struts on the rear hatch have failed.
    Hasn't missed a beat apart from that. Just getting pricing etc for the 45k service.
    Thanks for the tip on setting the service intervals on the dash
    Melbourne, Aus.
    18,359
    Thought I'd share this with you: I smacked a rock with the front under-tray last weekend then drove 150km home with it hanging down, but not scraping on anything. I visited our new Renault agent, Brighton Renault who whacked it on the hoist to see if there was any damage apart from the obvious. The news was good, no damage, the impact made a small hole in the tray and simply blew the plastic rivets holding the under-tray to the bumper clean off! I imagine they are not something you would find at most dealers so Brighton Renault kindly re-suspended the undertray on cable ties pending the arrival of the rivets. At NO charge! Most commendable, I'll be back! Four wheel driving Koleos owners need to be aware the under-tray is just a plastic splash shield, not a sump guard! Might keep some cable ties and plastic rivets in the car permanently from now on......
    394
    Any ideas for 'customising' my lovely Koleos? I have fitted front mudflaps (should be standard actually), also an aftermarket rubber 'door protector strip' along the vee on the lower part of the doors because that is very vulnerable to chipping in parking lots (looks shmick - not shown in the early picture at left, but you see what I mean about 'vulnerable') as well as door sill nameplates (are supposed to light up but there is NO WAY I am cutting into the wiring loom - need to connect them to the in-door foot lights), and a black plastic grill to protect the radiator from debris (gutter guard actually, from Bunnings, fits perfectly and costs nothing) I need more ideas.
    394
    Does anybody read this stuff?? Perhaps there are no more than two Koleos (aka QM5) owners out there?
    I have another question: I have just installed a reversing camera and discovered to my dismay that my model does not have an accessory plug in the boot like my wonderful Scenic had. Now I have to use the one in the centre console for the rear camera and the one in the dash for the screen-in-rearview-mirror. This means that there are visible wires running from back to front and both cigarette lighter plugs are occupied. (not that I need them normally but it does look unprofessional and untidy and the wires get in the way). I would like to run hidden wires to the fuse box and free the two cigarette lighter plugs for things like an iPod, phone charger etc.
    QUESTION: does anyone know how to tap power for accessories from the fuse box??
    Like I said above, I am wary of messing with the electrics (still have not connected my fancy and expensive illuminated sill-plates in the doors for fear of causing a fireball and massive short in the system!)
    Any auto-sparkies out there? Advice would be very much appreciated. Thanks
    Bricolage likes this.
    Jun 2003
    Lauderdale, Tasmania
    2,888
    The Koleos has a multiplexed system and it is not easy to connect without specific Renault accessories. You may be able to hard wire from the back of the 12v outlets if you can find your way through the trim to do it neatly.
    Feb 2011
    Perth
    21
    Weird...my Koleos has a rear accessory plug
    394
    Quote Originally Posted by Pieman View Post
    Where is the rear accessory plug situated? I suspect that my humble 'Expression' does not run to such luxury?
    Feb 2011
    Perth
    21
    Drivers side on the sill of the rear quarter window. Don't worry my wife blew the fuse in the ciggie lighter in ours with a shonky phone charger so we are probably even stevens for functioning accessory sockets!!
    Koloelol in for iot'[s 45K service this Friday so we'll see how brazen the dealer is to fix it...
    Jun 2003
    2,888
    I spoke to a Renault representative with a Koleos today and he showed me the accessory socket which is on the sill of the right hand rear side window facing forward. It is just a typical cigar lighter style socket. He says that if you want to fit a rear facing camera, you dismantle the rear door and there is an opening available through the centre of the Renault Lozenge. The wiring is multiplexed and you cannot connect without the modules from the factory. Alternatively you could remove the trim below the accessory socket and wire to its rear which is 12v demultiplexed. However, he pointed out that the labour involved in doing a neat job of feeding the wire to the door or to an alternative location on the bumper would be very time consuming.
    394
    Right, I found the place in the right hand rear quarter window where the socket should be. Unfortunately my humble Expression only has a plastic blank instead of a socket outlet. A bit of a nuisance that. And a bit silly really because in a vehicle that may be used for excursions and camping the socket in the cargo area should be mandatory and would not be a great additional expense, surely. Disappointing to say the least!
    Oct 2005
    Rome
    2,660
    If the 12v socket is de multiplexed, go and buy a generic one from a Repco/Supercheap Auto place? Only cost a few bucks and fit it yourself.
    Dave
    ​1997 BMW K1200RS
    IR655
    19,211
    Power your reversing camera off the reversing lights.
    The camera will only draw a few milliamps and should not upset nor overload the multiplex switching.
    You may get some disturbance on the screen when reverse is first selected due to the camera initialising but that should not be a problem.
    You will still need to run a video a feed to the ICE unit, unless you can find and use the factory fitted cable.
    394
    Thanks everyone for your very useful input. Multiplexed versus de-multiplexed? It's all Greek to me! I am tempted to ditch the reverse camera installation because it is not worth the trouble. The 'Response' unit with in-mirror LCD monitor I got from JAYCAR is just about useless because the reflection from the black-glass mirror supplied obscures the image. You end up with a seriously compromised rear-view mirror and a useless reverse camera view. I strongly advise against this expensive bit ineffective unit. Perhaps someone can suggest a better one.
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,488
    Just a possibility - even if the rear 12v socket is not fitted in the Expression - maybe the harness still has the socket hanging out of it, not connected to anything. Worth a look behind the trim panels?
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Jun 2003
    2,888
    Sorry, I can't help in Greek but can give a simplified explanation in neo-english. The car makers found that they could cut the cost and weight and copper usage of cable harnesses, not to mention the high current connectors and the manual labour of harness making by multiplexing. They use one high current cable or bus to supply a number of electrical loads in the car. The switches become a low current device much like a computer keyboard switch. This sends a simple code down the cable which contains an instruction like on or off or dim in simple binary preceded by another simple binary code which is the address of the load device being controlled. At each load is a chip which listens on the bus for its own personal address. When it hears it, it, then using some logic and a power semiconductor switch, it does what is required.
    If you add loads to the bus you have to make sure that they do not short out the high frequency operating messages flying around and don't send interference themselves. The multiplexed devices have appropriate filters; other electronics, relays etc. may not.
    The overall effect is that you cannot easily hook things onto the bus and you have to have the coded switch and decoder chip data which only the manufacturer supplies.
    Oct 2005
    vic
    858
    Default Fuel tank capacity?
    2L dCI 6 speed manual.
    Last fill was just under 55L for just over 700k's.
    Haven't put any more than this in the tank.
    Low fuel light on.
    Has anyone put more than this in their tank???
    David
