Renault RX4 gearbox help needed URGENT
Results 1 to 3 of 3
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    Default Renault RX4 gearbox help needed URGENT
    Hi I have a small problem with a rx4 scenic gearbox
    the passenger side drive differential hub that the drive shaft slides into has spat the retainin ring out into the rubber drive shaft boot, picture of ring attached, I put it back in by inserting it with the tag in the corresponding notch in the gearbox and then rotated it 180 degrees, drove it for a week then it happened again, the drive hub must rotate the ring till it lines up with the notch then the ring falls out. does anyone know what hold this ring in? and should there be a thrust washer between it and the drive hub. all help greatly apreciated.
    Sheffield/Tasmania
    631
    fixed it found out there was a part missing
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,341
    where'd you get the new one from?
    Cheers Chris
    2017 Renault Koleos auto
