Heavy Duty Clutch options for Fuego?
Results 1 to 25 of 25
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Heavy Duty Clutch options for Fuego?
    Anyone had a heavy duty clutch made up for a Fuego or fitted an off the shelf Exedy Heavy Duty clutch?
    I'm hoping it all holds up as I think I am pretty sympathetic to clutches but I'm not particularly optimistic that it will hold up long term with what will may end up being a 100% power increase...
    Anyone have any suggestions or advice?
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    First obvious choice is put a "good one" in, ie a Valeo.
    Second is find out what the R21 Turbo boys in the UK use - sure there are plenty of high performance options around for those that may fit (engine/flywheel the same, not so sure about the input shaft splines).
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    I don't think they are the same. That would be too easy
    May 2002
    canberra...
    8,752
    Quote Originally Posted by mistareno View Post
    Indeed... "standard" NG3 clutch plate and high performance UN1 pressure plate?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Maybe I'm wrong and an R21T clutch will bolt up. I was always under the impression a UN1 had a different input shaft?
    Helix Clutch info
    21 2.0ltr Turbo
    Application Type Cover Plate Bearing Spline
    Road N 235 60-4695 70-4696 40-4330 24 x 21T
    Exedy Clutch info
    Fuego 2.0 J6R
    Road 215 24 x 21
    May 2002
    canberra...
    8,752
    Dunno about the input shaft splines, but you can get "performance" clutches for Fuegos
    http://www.europerformance.co.uk/pag...sub_category=1
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Hmmmm. Thanks for that.
    I wonder whether the Diesel model would have more clamp pressure (higher torque at low revs?)
    May 2002
    canberra...
    8,752
    Exactly how much extra power are we talk ing here..? Chuck a standard in and see how long it lasts first maybe?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    cough 200 cough...
    It has a good standard clutch ATM. It may even be the original as the car had only done 120K when I got it (it lasted 300+K in my old Fuego)?
    May 2002
    canberra...
    8,752
    I reckon a good standard would do long enough. You're mechanically sympathetic and I reckon you'll be breaking NG3 spider gears if you hammer it that hard.
    They're cheap enough from Ken, see how it goes before deciding teh expensive option is needed...?
    Member 12vFuego's Avatar
    Jun 2004
    77
    Was looking into clutches a while back for my 12 Valve into Fuego project that is nearing completion.......found out the 21T's have a bigger diamater and dont fit. Unless you could get your hands on a 21T flywheel? Found out the 12 valve came out with a slightly uprated clutch as pictured. 4 double springs on the clutch plate instead of Fuego's 6 singles. Ordered one from the UK for a 12 valve and ended up getting the same 6 spring as fuego. Have just put it in for now to suck it and see.......
    I'm sure someone local could help up-spec the pressure plate if they are not up to the task. Mine's all bolted in now and part of 500 possible fail points since I have modified/rebuilt/re-wired EVERYTHING from scratch!!!!!
    BTW Mistareno......you are turboing?? I am holding on to a high quality 21T Head Gasket in case I need to de-compress my motor....was too thick for my build but if you are interested let me know.
    bob
    bob is offline
    May 2001
    Skipton
    2,382
    G'day,
    when a mere lad, I fitted an uprated pressure plate, as you did way back when as part of the big bores lumpy camshaft etc etc....
    and promptly bent the release fork... Not a froggie but no doubt the same Murphy truths apply.
    cheers,
    Bob
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by 12vFuego View Post
    Yes, definitely interested as I was going to have to chase up one eventually from the UK.
    Where did you source it from and what are you after for it?
    Jun 2004
    77
    One of the main guys on the 21toc UK forum helped me out a lot trying to get parts for my 12 Valve....ended up not being able to use quite a few things.....
    Looks like I paid 65 pounds for the HG. Thought it was more actually. Pretty serious looking gasket with all bolt holes etc metal reinforced. From memory I think it was about 1.7mm thick but can check tomorrow if needed. PM me if you need it.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    1.7mm might be handy for my application actually as I am running a 9.9 C/R engine. Even turboed, it should still be ok as it is on LPG but the thicker gasket would give me some head space.
    Jun 2004
    77
    Yeah I'm not up on my LPG Turboing or what boost/comp you can run......sounds very interesting. At what point will the LPG be added? Are you injecting as liquid or gas??
    Have to do the calcs but I'd expect this HG would get you to the mid 9's......
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    It's been on straight LPG for a few years with a Gas Research Throttle Body. They are used on a few High Power VL Commodores in a blow through configuration with a lot of success.
    It was always the plan to have it turbocharged, just took a while to get around to it.
    I'll start a thread when the exhaust is fitted and it's running.
    Jun 2004
    77
    So where are you up to on the clutch options?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    It has a good standard clutch in it. I'll see how that goes and if/when it struggles I might fit an Exedy heavy duty one.
    I have changed the pivot bushes to a bronze impregnated sintered bush (or something like that) and the pedal is very smooth an light atm.
    If it stays that way (after the 'gloss' of greasing everything has worn off) I'll assess whether the standard setup (with the better bushes) can handle a heavy pressure plate (which is what the Exedy is)
    Jun 2004
    77
    I guess I will also see how the std item goes first and then deal with it if necessary. Is the Exedy a locally available item?
    I have fitted the hydraulic clutch set-up from the 25 to mine as I am running a UN1. Hope It all works and doesn't have to come out again in a hurry!
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Yeah. the Exedy is available locally.
    Did you fit the clutch master internally or externally?
    What driveshafts are you using with the UN1 (or did you manage to widen the track a bit and use the standard ones?
    Jun 2004
    77
    Extended and modified my standard pedal estensively to run pushrod to Master on firewall (very tight fit alongside booster) with remote resevoir. Got all components fully resleeved/rebuilt so hopefully they won't need attention for quite some time.
    Playing around I discovered that you can put the R25 Inner joints (gearbox end) on a Fuego shaft and you end up with the perfect length shaft. Fuego too short, R25 too long and thick diamater of shaft gives clearance issues with body at droop. But the combo above is perfect and clearances like shaft travel seem pretty close to spot on. Yet to be driven and tested though
    Oct 2002
    Melbourne Victoria
    11,800
    Scratching through my old records here I found a reference that I purchased Clutch components mid 2000 from a Grant Vincent for $187 Clutch plate PBR #RW8634 W and exchange assembly #X850 -573 with SACHS thrust bearing # 3151 846 001, this was apparently an Australian built up heavy duty clutch, and I put it into Di's car that is now in Launceston, clutch is still going...
    In those days Grant Vincent operated out of 15 Macquarie Drive Thomastown,(RPM/PBR Clutch) phone # was 9463 2200 Grant had taken over from Ratz Clutch that was previously owned by Phillip Handcock - Dianne was a friend of Peter Handcock Phillip's son, both having worked on the Ivanhoe Rovers Mudbash car and she had previously had a RATZ heavy duty clutch put in her then daily user Fuego (soon to be scrapped)
    Don't know if Grant Vincent is still involved in the brake and clutch business - probably gone years ago, but you never know!!
    Ken
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Kenfuego View Post
    Ken
    There is still a clutch place at that address so I'll give em a call. Thanks Kennel
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    I looked into both options and was leaning towards an internal master (through laziness /ease )but the clutch feels so good atm i might put it on the back burner.
