Keys for Renault 750
Results 1 to 10 of 10
    Tadpole Rob Toogood's Avatar
    Aug 2012
    Ballarat
    10
    Default Keys for Renault 750
    Does anyone know where I could get an ignition key cut for a 1955 Renault 750?
    bermagui
    34
    Blank should be the same as R10 R12 R16 and 504.
    Aug 2012
    Ballarat
    10
    Thanks, will try to locate
    bermagui
    34
    Thought someone would have been able to give you some more help. It has been some time since I had one cut. Any good locksmith should be able to help you. This may help 4cvregisteraustralia.org .
    Feb 2005
    rosevale/tasmania
    2,744
    I've found a local keycutter with some old blanks, so give me a week or so to get around to it & I can probably get some & post them on. Peter
    Simon's Avatar
    6,161
    Quote Originally Posted by gordini17 View Post
    It may not be. A 750 may be fitted with an ignition key start or the Neiman type steering lock ignition switch, some of which use a different key to the R10. Firstly the ignition switch fitted to the actual car should be identified. An R10 and 12/16 ignition key are both different to each other.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Simon's Avatar
    6,161
    1963 Renault R4 Van
    1964 Renault R4
    10,754
    Simon is right (I could add "as usual"). My 1951 4CV has a Nieman but the key is indeed different from the key for the Nieman in my 1964 R8.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Aug 2012
    Ballarat
    10
    That would be fantastic, thanks.
    Aug 2012
    Ballarat
    10
    Mine is a 1955 model - I don't take possession of it for 2 weeks, Il
    'll have more info when I see the (only) key
