8:08 State. RS Megane 265.
    Simon's Avatar
    6,162
    Default 8:08 State. RS Megane 265.
    Renault have just released the RS Megane 265 range to Australia:
    Ripped from GoAuto: http://glassguide.goauto.com.au/mell...257A61008332F0
    Renault’s Nurburgring-busting Megane RS265 finally makes it Down Under
    22 August 2012
    By RON HAMMERTON
    The fastest front-wheel-drive production car around Germany’s Nurburging has landed in Australia among a quartet of smoking Renault Sport Megane RS265 variants designed to help the French car-maker repel interlopers in the increasingly crowded hot hatch market.
    With Ford’s 184kW Focus ST just two months away and at least three other European-bred hot hatches on the horizon – including Volvo’s 187kW V40 T5 – the French company has turned up the heat with the upgraded Megane sports flagship.
    Packing an extra 11kW of power and 20Nm more torque than the superseded Megane RS250, the 195kW/360Nm RS265 lapped the famed ‘Ring Nordschleife in just 8:08 minutes with Renault development driver Laurent Hurgon at the wheel in June last year.
    Belatedly, that version of the three-door Megane RS has shown up Down Under in four flavours, including a special edition – dubbed RS265 Trophy 8:08 in honour of its benchmark time – armed with the same sticky Bridgestone tyres and Recaro sports seats used in the German hot lap.
    The bad news is that Renault Australia is importing just 100 of the Trophy 8:08 hatchbacks for Aussie customers this year, but the good news is that three other RS265 variants without sales restrictions are also on the boat from Spain, where this model is made.
    The ‘standard’ models start with the RS265 Cup ($42,640 plus on-road costs) and step up to the RS265 Trophy ($47,140) and range-topping RS265 Trophy+ ($51,640).
    The Trophy 8:08 special edition comes in between the Trophy and Trophy+, at $49,990.
    The price for the base Cup reflects a $750 price rise over the previous RS250 equivalent, while the Trophy, which used to be called Trophee in the French fashion, goes up $150.
    The Trophy+ is new to the range, boasting a higher level of features than ever before.
    According to Renault legend, the RS265 was the brainchild of French gendarmes who wanted more poke from their crook-catching RS250 pursuit cars.
    The ‘265’ refers to the horsepower of the feisty turbocharged 2.0-litre four-cylinder engine, translating to 195kW.
    To achieve the extra performance, Renault turned up the wick on the turbo pressure by 0.2 bar, to 2.5 bar, while also modifying the air intake to suit.
    The result is one of the hottest front-drive hatches in captivity, crunching the 0-100km/h sprint in a neat 6.0 seconds (one-tenth quicker than the RS250) and matching its nearest logical competitor, the Volkswagen Scirocco R.
    Full power only comes on tap when the driver selects sporty modes in the new electronic RS Dynamic Management system.
    In the standard mode for everyday driving, the power is restricted to a mere 184kW – the same as the previous RS250 – while engine mapping and ESC controls are controlled for smooth performance.
    ‘Sport’ mode eases off the ESC control for more corner action, while the engine mapping is adjusted to not only increase throttle response but also to boost power and torque to the full 195kW and 360Nm.
    The driver can throw caution to the wind with the ‘Off’ mode, which disconnects the ESC altogether while unleashing full kilowatts.
    To add to the driving satisfaction, the sportier driving modes also deliver “an attractive and intoxicating burble” on overrun from the exhaust, which has fewer obstructions than before for a meatier note at all revs, including idle.
    Peak power is delivered at 5500rpm, while 80 per cent of the torque is available from 1900rpm, with all 360Nm peaking at 3000rpm.
    Although the engine has been let off the leash, Renault Sport has managed to tame fuel consumption by 5.7 per cent, to 8.2 litres per 100km on the official combined test cycle. Carbon dioxide emissions are down from 201 grams per kilometre to a claimed 190g/km.
    As before, the fastest Megane is equipped only with a six-speed manual gearbox, driving the front wheels.
    To help tame the front end, the RS265 employs a limited-slip differential and Renault Sport Technologies’ steering axis front suspension.
    The latter shuffles the front suspension and steering components to separate the steering axis from the damper to minimise the dreaded torque steer suffered by most high-power front-drive cars.
    All RS265s get a new function, RS Monitor, to allow the driver to play race engineer by scrolling through a range of engine and performance data and even change the throttle mapping with a choice of five modes – snow, progressive, linear, sport and extreme.
    The display screen can show real-time power and torque figures as well as G-forces, while the stop-watch function can memorise the best 400-metre standing start and 0-100km/h sprint times.
    If things go pear-shaped, stopping power is supplied by four-pot Brembo front brakes with 340mm discs (290mm on rear).
    Exterior teaks on the RS are minor, with LED daytime-running lamps perched at the front on what Renault describes as the F1 blade.
    For a little extra show, drivers can opt for the $890 Red Design Pack that adds distinctive red striping across the front splitter, around the alloy wheels and down the side bump strip.
    The entry-level RS265 Cup gets Renault Sport cloth front seats, 18-inch alloy wheels, eight airbags, Brembo four-pot front brakes, auto headlights and wipers, LED daytime-running lights, rear parking sensors, dual-zone climate-control with an air quality sensor, Bluetooth with audio streaming, heated exterior mirrors and space-saver spare wheel.
    The mid-range RS265 Trophy gains Recaro front bucket seats with cloth trim, 19-inch alloy wheels, keyless entry and start and tyre pressure monitor.
    Moving up to the flagship RS265 Trophy+ means top-shelf leather-trimmed seats with heating, electrical adjustment and memory functions, along with sat-nav and reversing camera on a seven-inch screen, bi-Xenon directional headlights, fixed glass roof with a shade cover and front parking sensors to go with the rear sensors.
    The limited-edition RS265 8:08 comes with 19-inch wheels fitted and the Bridgestone Potenza RE050A tyres, the leather-trimmed Recaro seats, bi-Xenon directional headlights and two unique colours – liquid yellow and pearl white.
    Renault Megane RS265 pricing (plus on-roads):
    RS265 Cup $42,640
    RS265 Trophy $47,140
    RS265 Trophy+ $51,640
    RS265 Trophy 8:08 $49,990
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    While we are into news:
    _____________________________
    Renault confirms Clio lineup
    Date August 22, 2012 - 8:50AM
    Matt Campbell
    Motoring Writer
    Renault has confirmed it will take on the likes of Volkswagen's Polo, Honda's Jazz and Ford's Focus in 2013 with the arrival of its new city car, the Clio.
    The current generation Clio is only available in a high-spec, high-performance Renault Sport variant, the RS200, which is expensive even by hot-hatch standards at $36,490 plus costs.
    But the new range is set to bring the French brand into the entry-level segment of the market, with Renault Australia confirming it will offer a number of variants of the new Clio when it arrives here around June 2013.
    The new model, a five-door only car, is expected to play a crucial role in the car maker's fortunes Down Under, with Renault Australia CEO Justin Hocevar confirming the new model range will be comprehensive.
    "We're going to open it up to a number of other markets, including diesel and petrol," Hocevar says.
    The company confirmed the new Clio will also be available with both manual and automatic transmissions, but wouldn't be drawn to comment on the possibility of whether the cheaper, more frugal but less powerful three-cylinder petrol engines would be offered here. Instead, it is expected Renault will offer a 1.4-litre petrol and 1.5-litre turbo diesel.
    The company wouldn't comment on pricing, but it is expected the new model will be positioned among its chief rivals such as the Ford Focus, VW Polo and Honda Jazz, with pricing expected to start close to $17,000.
    Renault Australia also confirmed the new hot hatch RS Clio models will only be available with a dual-clutch automatic transmission, doing away with years of tradition which has seen the sportier models offered only with manual gearboxes.
    The company says the new Clio RS is due here late in 2013.
    http://news.drive.com.au/drive/motor...822-24lbp.html
    Fellow Frogger! RickHy's Avatar
    Nov 2005
    Geelong
    378
    sold a ltd Ed pearl white already today
    Rick
    Geelong Vic
    2012 Koleos Dynamique - Family Wagon
    PAST:
    Clio RS172 .... Silver - Damn strong car !
    10 Fluence Privilege Sedan Black
    07 RS225 3 door - Monako Blue
    07 Megane Privilege Sedan Black
    Chevrolet Corvette- red of course
    Nissan Skyline GTS turbo - fantastic machine
    Alfa Romeo 33 Quattro Wagon -ebayed for profit!
    Fellow Frogger! DanielBendigo's Avatar
    Mar 2012
    Bendigo
    655
    Damn, I read Wheels, and was expecting the new Clio would just have the 67kw turbo 3cyl, the 1.5TDi, and the 89kw 1.2 turbo 4. But on re-reading, it doesn't actually say they're for Australia. Still the 1.4 in the Clio 2 had enough power (for a 1.4). Hopefully the new will have even more power.
    The Megane RS265 is the car I dream about! Unfortunatly the Clio 1.4 will probably end up being the car I buy.
    Member minigolf's Avatar
    82
    I have heaps of RS265 info on AUSmotive, including 50 x 2000px photos and detailed press info.
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    839
    Can highly recommend Ausmotive. Very in-tune with the quality Euro cars
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
