Buying a Clio Sport 2002 (TIMING BELT)
Results 1 to 8 of 8
    Aug 2012
    Toowoomba
    3
    Default Buying a Clio Sport 2002 (TIMING BELT)
    Hi all,
    I am having a serious look at a 2002 Clio Sport with 120 000 km BUT the timing belt service was skipped. There is a history of the other services including the aux belt.
    If I was to do this service straight away do you think all will be OK, or is it a bit late?
    John
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    How can it be a bit late.. it is late!! so just do it as soon as you buy it, and all is good
    Mar 2005
    318
    factor the timing belt change in as soon as you get it. use this to haggle the price.
    it's not hard to do yourself, i've brought an RS clio back from bent valve doom.
    doing it yourself is a good thing, means you actually know it was done, and done properly...
    Fellow Frogger! MIKEEE's Avatar
    Mar 2003
    417
    The timing belt is a known weakness. The fact you're querying it shows you've done your research already.
    Good luck, and I hope you end up with a good'un.
    Fruit images shown are illustrative of flavour only and are not ingredients of the product.
    8,397
    Quote Originally Posted by johnno23 View Post
    John
    DO you understand that a timing belt either works perfectly, or fails monumentally causing obvious engine damage and a state of no-start??
    There are not too many in between states for a timing belt.
    SO your belt change may be a bit late, but its not 'too late' if the motor still runs.
    It's only "Too late" after the belt snaps.
    Jo
    Simon's Avatar
    6,162
    Don't forget, that it isn't just the belt that requires changing. Also the plastic tensioner pulley and bearing kit must be changed, as well as the serpentine belt and pulley tensioner. And whilst you are at it, you may as well do the water pump as it is more accessible. From a Renault dealer the whole belt service is circa $2-2.5K.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Member Philby's Avatar
    34
    Don't use a Renault dealer! I bought my belt kit and water pump from Ken at Caravelle in Melbourne and got an independent garage to install the lot. It came to more like $800 from memory (about 3 years ago). Damn, it's nearly due again!
    Oct 2005
    Rome
    2,660
    Jo
    So true
    Dave
    ​1997 BMW K1200RS
    IR655
