R17 front caliper seals info wanted, pls
Results 1 to 7 of 7
    Nov 2005
    Geraldton
    1,565
    Default R17 front caliper seals info wanted, pls
    Need to overhaul the front Calipers on the 17.
    Ken at Caravelle is out. Can anyone tell me what diameter they are or even a part number. Vehicle has drums on the rear.
    All the best
    Ex
    In the Shed(s):
    In the Past:
    Ove
    Ove is offline
    Germany
    68
    Hi,
    except for some US export-version (R1316) all other models (R1312, R1313, R1317 and R1318) have 54mm pistons. The same brake was used in Fiat Ritmo Abarth.
    The repair-kit can also be taken from Renault R20TL.
    Here is a link showing different references:
    http://webcache.googleusercontent.co...&hl=de&ct=clnk
    Ove
    Simon's Avatar
    6,161
    Caliper seal kit:
    Renault P/N 7701 010 268 superseded by 7701 200 699
    Caliper seal & piston kit:
    Renault P/N 7701 010 264 (R1312, 1 - approx 48735, R1322, 1 - approx 6111)
    Renault P/N 7701 200 798 (R1312, 48736 approx onwards, R1322, 6112 approx onwards)
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Nov 2005
    Geraldton
    1,565
    Gentlemen, as always, many thanks.
    P
    In the Shed(s):
    In the Past:
    Nov 2005
    Geraldton
    1,565
    Update
    Simon,
    The chap at Renault (City Auto) said that cars that old don't come up on the computer any more and it did not recognise any of the numbers, including many of the oval plates. It appears that Brendon no longer works there.
    Ray,
    PBR seem to have vanished into the ether. The part number you gave is not recognised by Repco and the Bursons system listed it NLA. He suggested I call ABS.
    ABS recognised the number you gave me (K746S) and were able to match it to a kit that was NLA. However there were more than 400 seals avaliable on the east coast but no dust boots.
    As an afterthought I asked what they had for an R20TL. Kits were avalible to suit a 54mm piston. I ordered 4 at $25 each. The risky part is that I haven't pulled the calipers down yet.
    I will post part numbers when I get the sets.
    Thanks again,
    Peter
    In the Shed(s):
    In the Past:
    Ove
    Ove is offline
    Germany
    68
    Jun 2004
    396
    I've just ordered a set of seals and pistons from mecaparts.com
    Not that cheap, about $80-100 landed, but easy to get.
