fuego dynamic camber
    8,395
    Default fuego dynamic camber
    For anyone interested, I measured the dynamic camber of the fuego as its suspension travel from droop to full compression.
    Basicly you see about 1 degree ether way from my estimated OE ride height which is lower arm slightly sloping down from the body
    So at full compression there is -1 degree referenced to standard ride height, and at full droop, +1 degree.
    Jo
    Feb 2005
    rosevale/tasmania
    2,744
    of interest also is the shift to increased -ve as lock is wound on.
    Peter
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    They do seem pretty good in that regard.
    I remember years ago waiting for some tyres to be fitted to my old Fuego.
    The car was in the air with it's suspension at full droop and there was a BMW 3 series (E36 from memory) next to it in the same position.
    The BMW must've had 4-5 degrees of + camber and the Fuego had no visible + camber yet it's wheels were hanging lower - admittedly the old fuego had a touch of - camber at ride height but the contrast was stark.
    One day I'll have to measure exactly what difference to in turn camber cranking on some more caster makes.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    Positve camber in the droop state is not a bad thing - that's the inside when body roll is happening and positive camber would improve tyre contact.
    How much is good depends on how much it rolls I guess!
    8,395
    8.25 is the max roll in a fuego.
    Jo
