Megane engine mounts
Results 1 to 17 of 17
    16,370
    Default Megane engine mounts
    I dropped the C4 in to day for a roadworthy.... And got chatting to the mechanic there. He had one of those "Renault Megan" things come in on a flat tray. It was making really bad knocking noises.
    So he jumped in to drive it around the block and see what the noises were................. and .................. The motor fell out on the road while he was moving along it separated the driveshaft joints and everything.
    So listen up, if your megane breaks it's engine mounts... the engine must no longer be contained And will fall out! Bloody hell, every citroen I've owned with destroy the rubber in the mounts, but the engine stays contained, it's just rattles and bounces around like buggery
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,748
    Sounds like BS to me. Not possible with rubber breakages. Bolts would need to be severed.
    Jan 2005
    Melbourne NSW
    813
    I've seen a megane sever the top TH bolt, even have a picture of it somewhere. Engine didn't "fall out" though....bit hard to fall out when it can't fit through the lower subframe....
    Current stash
    too many.
    Passed over stash
    lots.
    Jan 2005
    Melbourne NSW
    813
    Top RH bolt....
    Current stash
    too many.
    Passed over stash
    lots.
    Dec 2010
    Blackburn Victoria
    474
    Those who know, will always replace the East - West bolt when the mount is replaced.
    They do fatigue and can snap without warning.
    BUT I think the engine falling out of the car is B.S. too.
    Too many other bits and pieces to keep it at least somewhere in the engine bay.
    AND you have to ask WHAT this supposed mechanic was attempting to achieve with
    what would have to be a BRUTAL test drive. There are other more sensible ways to
    diagnose bad noises...
    YEAH I personally hate V8 dinosaurs, and I bet I could destroy some or all of the driveline
    if iI were to drive it with hatred....
    16,370
    Quote Originally Posted by Steve K View Post
    He said it was delivered with terrbile noises on a fllat tray. He reckoned the owners lived up a bush track that would make a 4wd gulp hard.... And they were driving this car up 'n' down it. I tend to believe the motor "fell out" as he suggested as he even stated the driveshafts came apart at the joints etc....
    Dunno how it's possible, but it must have happened Sounds like they backed it off the truck and tried to drive it around the block to get an idea of the "awful sounds" it was making, but didn't make it.
    It's a RWC testing place. They'd have all sorts through, he said they had a V6 407 through recently (and he said it was a heap of sh!t to work on ..... It probably is Especially if it was a V6 HDi squeezed in there).
    Oct 2005
    Rome
    2,660
    Come on Shane. You've spent enough time under your heaps of shit to know that an engine can't fall out onto the road. Even if that could happen, the firewall and passenger compartment wouldn't take kindly to 100kg plus of engine and transmission suddenly appearing on the tarmac...
    Seems to me to be an urban myth, where the listener is supposed to a) say "Wowwwww!" and b) retort with, "Typical French shit".
    I say bullshit!
    Dave
    ​1997 BMW K1200RS
    IR655
    Boonah Qld
    2,523
    My sons Megane top engine mount and the noise was such you probably shouldn't drive it. But engine fall out don't think so.
    http://renaultinaus.17.forumer.com/viewtopic.php?t=586
    Dec 2010
    Blackburn Victoria
    474
    Shane,
    My advice is DON'T LET THAT MOB TOUCH YOUR CAR!
    Look at the Holden, Ford and Toyota forums
    Probably see some great yarns about what they did to some (not you) mug's Citroen...
    May 2002
    canberra...
    8,748
    What Steve said. Mechanics that give a sh!t and/or care are awefully rare. Mechanics that thinks its cool/funny to trash customer cars depresseningly common.
    Should have said to someone on the phone the other day that only two people on this planet will ever lay a finger on the timing belt on my Megane, and they're talking to each other....
    16,370
    Oh gee's,
    there actually known for sheering off engine mount bolts . Well that makes sense, pretend someone that knows little about cars is beating one up and down a 4wd track to there house each day .... they break the top engine mount bolts, yet continue to drive (for possibly even months) until the other mounting bolts eventually fatigue and break off.....
    They finally call a flat tray the day all the bolt fatigue and break off because of the "horific banging noises" under the bonnet
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Oh gee's,
    Is it possible that the car has had several big impacts underneath and snapped all the subframe bolts causing the whole sub frame (engine/gearbox and all) to fall onto the road?
    That would be rather catastrophic...
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,956
    I'd love to see the evidence of any of it. Anyone know what "hearsay" is?
    It's something that isn't allowed in court. If you can't provide evidence of the "alleged" incident, perhaps you could impress members with these kinds of anecdotes by putting them in the Humour section.....
    CitroŽn Tragic UFO's Avatar
    9,700
    Quote Originally Posted by Kim Luck View Post
    Oi! It's the humour section, not the "convenient place to dump an argument that doesn't fit elsewhere" section. We have a toad pond for that!
    Feb 2001
    Romsey, Victoria, Australia
    4,821
    Tells us the rest of the story Shane.
    What happened after the engine fell out. Did he stop and pick it up or keep driving round the block pretending nothing happened
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    9,700
    Yeah, to revitalise a phrase "pics or ban!"
    16,370
    I was just impressed he new what a renault megane was let alone could tell a story about one..... I don't think there is even one living in ballarat!
