WTD R5 Rocker Cover Bolt
    634
    Default WTD R5 Rocker Cover Bolt
    Does anyone have a spare rocker cover bolt to suit the R5 (847) engine.
    See photos
    Angelo
    10,769
    Quote Originally Posted by R8 Dream View Post
    See photos
    Angelo
    You'd find something else with that thread to fit with appropriate washers at the top I'd have thought, if no-one can help with the exact bolt. I've never seen one quite like it with respect to shank vs thread diameter.
    Good luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,646
    Default Cover Bolt !!
    Hi Angelo,
    My One in the UK and the one I am working on at the moment, have a stud in the rocker pedestals and a thumb nut on the top like normal R10/R16. They have a special washer with a locator shoulder and a gasket washer. They are in being plated at the moment, so no picture.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    634
    Any reason for the larger shank, as I can fit a HS 8.8s bolt in with the correct thread and can easily weld a 3mm washer in and use a felt gasket that will hold the rocker cover down.
    Perth, WA
    1,646
    Default Bolt Shank !!
    Hi Angelo,
    The shank is more than likely to locate the cover, and the length is to stop in the thread, so you do not pull it down too much.
    Ray
    Ray geckoeng
    634
    That makes sense!
