valve spring compressor
Results 1 to 10 of 10
    8,484
    Default valve spring compressor
    As the title suggests, I am in need of a valve spring compressor for my fuego.
    The cheap and nasty one that I have does not clear the edge of the head so is useless.
    What type of compressor should I get that will fit neatly and not be a pr!#k to use ??
    Jo
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,337
    Default Valve Spring Compressor
    Hi Jo
    I made my own, can take a pic if you like.
    But not sure if it would work on a Fuego head.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    9,321
    ACHTUNG ALLES LOOKENPEEPERS
    Oct 2005
    vic
    868
    Jo, yep, used that style on my last valve spring removal job on the Fugs head - worked a treat (at least mine did).
    David
    8,484
    I like the look of that type of tool, as it does not look like it will slip off and scratch the head.
    The question is will there be some sort of 'renault thing' that will impede placement of the tool.
    Jo
    8,484
    Quote Originally Posted by 85Fuego View Post
    David
    Ahh, there is the advice I was after.....Thanks guys.
    Jo
    Newcastle
    2,800
    Default The future ?
    Hi,
    That unit might work Ok on the Feugo as stated.
    However if you move on to do some newer 4 valve heads in the future it probably will not fit them. The springs are recessed in the tappet 'holes'. Just a thought as you spent the dollars.
    Jaahn
    8,484
    Hi,
    Not likely, but noted thanks.
    Jo
    Newcastle
    2,800
    Default /
    Hi,
    Here is a unit that looks like it might fit everything. Note I have not seen one or used one!! http://www.ebay.com.au/itm/8PC-VALVE...item519ea245a9
    Jaahn
    Perth Western Australia
    2,705
    Default compressor.
    Hi,
    Jaahn
    Amazing price for a compressor that looks like it can cope with most heads both old and modern.
    The selection of 5 adapters with cut-aways to access the colletts. When I think of the cobbled up things I made in the past.
