R8 Door Hinge Pin removal
Results 1 to 19 of 19
  • 1 Post By Kim Luck
Thread: R8 Door Hinge Pin removal
    654
    Default R8 Door Hinge Pin removal
    Hi All,
    Just spent 3 frustrating hours in the gareg trying to remove the door hinge pins from my R8 with success
    I see in the manual there is a special tool for doing this, but I imagine it would be next to impossible to source.
    Does anyone have any ideas how the pins can be easily removed?
    Burswood Western Australia
    428
    Easy... take a piece of solid round steel rod just slightly smaller diameter than the hole in the hinge and about 4 inches long. now weld another piece of rod about 10 inches long and weld it at right angles, close to one nd of the short piece of rod. now you have a suitable tool, place the end of the short piece of rod on top of the door hinge roll pin, hold it in place by using the handle to stabilise it in position, now take a small engineers hammer and hit the top end of the short piece of rod and drive the pin downwards... easy!
    4,422
    Frans or someone in NZ described grinding down a suitable size (8mm I think) Allen key on the "short" end so that the first 5.5mm of length is 6mm diameter, then 8mm rounded until it meets the "long end" - which means basically grind the high ridges off it so that it is 8mm round.
    KB
    KB
    Nov 2005
    Geraldton
    1,613
    Quote Originally Posted by Rod Slater View Post
    A tent peg works for me.
    In the Shed(s):
    In the Past:
    654
    Default R8 Hinge Pin
    Yes, 8mm is the correct size, and grinding the end bit helps keep the tool in place but as the pins are well rusted in and "tapping" the top of the tool just won't work without a little more effort than normal. Even with WD40, the bugger is just awkward to get to without damaging some of the door.
    I suppose I just have to be patient, and donít try it at night after a long day at work (ie: in a bad mood!)
    Member renogade's Avatar
    Jan 2011
    Armidale NSW
    109
    i have put a long bolt through the pin and a piece of iron rod had a nut the exact size of the pin and got a hammer and floged it out and the good thing is it holds the pin when you turn it around and put it back in took us under10 mins to take one door off and put it back on
    Kind Regards
    Ryan
    61 Dauphine Gordini r10 running gear - restoration
    "Speed has never killed anyone, suddenly becoming stationary... thatís what gets you"
    654
    GOT IT! GOT IT! GOT IT!
    Sol'n: 8mm 8.8s bolt, tap carefully and once it moves about 5mm, the remaining pin pops out easy. All 4 doors in 20mins
    Thanks guys for the great ideas.
    AS
    Fellow Frogger! r8waynerenault's Avatar
    Perth
    184
    Default R8 door removal
    Quote Originally Posted by R8 Dream View Post
    AS
    Trust me they all have different issues and some fall out and others need everything you got. What works for one may not work for the other. Look at how they were made, no door gap is the same, it was not a precision built car remember.
    Wayne
    Wayne Vernon
    Reno R8 63
    Falcon XT GT 1969
    Ford Single Spinner Ute 49
    Jun 2018
    Norway
    136
    I need to try to adjust some of the doors on my car. What it the easiest way to adjust door alignment on these cars?
    Since panel gaps where brought up here I thought I could ask in this thread.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,212
    I remember seeing a tool that had a short turned extension on the end of it which comfortably fitted into the compressed roll pin. It's stepped diameter meant that you inserted the short spigot into the roll pin before inserting or removing it. I think it had a Regie part number. Simples...............
    Melbourne, Aus.
    18,212
    Quote Originally Posted by R8RX View Post
    As the hinges are on welded extensions from the body a sharp tap in the required direction to align the doors correctly is just a matter of hammer skill.
    JohnW likes this.
    4,422
    You can also move the striker pad in or out (within reason) by undoing the three Phillips head screws, wont close the door gap but will help with alignment laterally.
    KB
    Jun 2018
    Norway
    136
    Thank you One door needs a bit of both. It is too far back and way too high at the rear.
    11,104
    Good luck. It would be interesting for us to see a photo of the door and its gaps for comparison with our cars. What do you mean by "too far back and too high at the rear"?
    These cars were not built to perfect standards...
    John
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jun 2018
    Norway
    136
    Don't think my car should be used as a reference since I think it's life has been pretty hard Panel gaps are out of place everywhere. Both doors on the driver side need serious adjustments. They need to be moved forward. The driver door touches the B pillar and serious force is required to both open and close these doors.
    11,104
    Eek. You've checked the body shell for cracks? I was just curious about how bad they are. Mine has twice been hit from the side (left side both times) and it isn't perfect although the vertical gaps look reasonable.
    Jun 2018
    Norway
    136
    Yes, I have been through many hours of welding on the car. Mostly because of rust, but also cracks. Can't see any clear signs of collisions on the body shell, but there are a few body parts with different colors on them when you grind through the top layer of paint.
    The driver door is very visible out of place, it doesn't have any damage, so it might have been replaced after a hit or something at one point without adjusting it properly.
    11,104
    Ah. That sounds like a lot of work! My car had a complete B-pillar fitted from a Renault 10 after its accident. Of course, it takes very little movement at the hinge pin for a lot of movement of the outer edges of the door!
    Good luck!
    Jun 2018
    Norway
    136
    Thank you
