Weber Manifold for 8 port sierra motor
Page 1 of 3 123 Last
Results 1 to 25 of 52
Like Tree23Likes
Thread: Weber Manifold for 8 port sierra motor
    DBR
    DBR is offline
    Tadpole DBR's Avatar
    Dec 2005
    23
    Default Weber Manifold for 8 port sierra motor
    I feel I may be out of luck ................however;
    Anyone know where I may be able to get Side-draft Weber /Dellorto manifold for the 8 port Sierra engine?
    Single or dual carb configuration, new or second hand - I don't care
    Had a look on the forum and at the usual suspects - nothing in Aus. It may be possible that Lynx/Ramflo in the US still make one - but I would rather source locally if possible)
    Denis
    Lots of Renaults and a P76
    4,261
    You may be out of luck.
    French auto care (in Brisbane) used to have non-pulsed ones like mine. I spoke to them last yr at the renaultsport expo and they no longer had some, but were a bit vague on whether they could still get them (apparently the guy who used to cast them retired).
    Caravelle had some lynx copies (Pulsed) which Rob M had had done a number of years ago.
    Maybe we should pull mine off after the next event and look at getting a cast made and go into limited production!
    KB
    KB
    Member dav17ts's Avatar
    yeoval
    67
    Default webber manifold
    if you are going down this path,try to find a pattern maker to do you a pattern so that when theavidy are cast & machined they fit without any trouble. if you tke a mould of your manifold it will be slighly bigger.
    david
    Feb 2001
    Romsey, Victoria, Australia
    4,722
    KB
    Instead of reinventing the wheel, why not try to find the bloke who did them for Rob M, the castings must be around somewhere.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    yeoval
    67
    it,s not the casting you need to make a casting it's the pattern.the problem is that a lot of castings made in the last few years are taken of castings( manifolds rocker covers ect ) & the are do not fit properly i have access to a pattern for 1600 motor for webbers ect which is bolt on no modes as we have on our 12 with 17 running gear .
    David
    4,261
    Good points from both David's.
    I liked the non-pulsed version better actually, so have a slight preference for that.
    DB - I actually meant getting a pattern made (is your Dad still up for it?), but my lack of correct techniques is evident.
    KB
    KB
    Feb 2001
    4,722
    Okay, I hear what your saying but I know Rob was quite fussy when getting his made and he got quite a few done, I'm just thinking you could save yourselves a bit of time and money by using the same people. It was only about 5 years ago so the patterns may not be lost yet.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    yeoval
    67
    not at this point in time as he is not in the best of health.i only wish he was as i still need some patterns made myself.
    David
    yeoval
    67
    sorry david i missed your post before i did mine yes you are right it would be cheaper to see if the pattern is still avaiable
    david
    Queensland , born a Croweater
    657
    Default try barry in toowoomba
    barry in toowoomba had a set in his display cabinet last time was there think was for twins his no 0746301699, hardest bit is getting him to sell anything a possessive wrecker is barry regards fish
    Nov 2002
    Yarrabilba, Queensland
    2,753
    Fish, I think they need a new yellow pages listing for ol' Barry...hoarders anon would be more suitable than 'wreckers'.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Fellow Frogger! Ross's Avatar
    Auckland NZ
    380
    Quote Originally Posted by DBR View Post
    Denis
    When you say an 8 port head do you mean the 1400 heads with the 8 totally separate ports or do you mean the 1300 head. I used Datsun 1200 manifolds on the Dauphine which used a 1400 head, they fit with a small amount of modification. I do have a twin carb manifold made for the Sierra motor, I have never used it and Im not sure exactly which head it was designed for. Not sure I want to sell it but if it is of any use to you as a pattern then I could post it over.
    Ross:
    1989 Alpine GTA Twin Turbo
    1963 Renault R8
    1996 Peugeot 106 S16
    1967 NSU Prinz 1200TT
    1989 Peugeot 205 GTi
    Auckland NZ
    380
    Just found a photo of the Datsun manifolds in the Dauphine
    Attached Thumbnails Attached Thumbnails Weber Manifold for 8 port sierra motor-dauph-engine-1.jpg
    Ross:
    1963 Renault R8
    4,261
    I think he has a 10S head on an 1108 sierra block presently. But he also has another car with a 1289 out of an R12. I've got the 1.4 engine out of the virage in mine.
    What are the differences between these three heads, and which would work with the Datsun Manifold?
    What mods are needed to make it fit?
    KB
    KB
    Auckland NZ
    380
    The Datsun manifold only works with the 1.4 head, only minor mods needed the worst being 2 small blocks either welded or screwed to the top of the head to take the top bolt of each manifold. Obviously a bit of porting needed to line things up.
    Ross:
    1963 Renault R8
    Moderator vivid's Avatar
    parallel 43 south
    1,810
    Quote Originally Posted by Ross View Post
    Such a nice neat setup Ross.
    David.
    Powered by high grade French plutonium.
    bob
    bob is offline
    May 2001
    Skipton
    2,231
    Default Renault weber manifolds
    G'day,
    came across these two...
    http://www.carburetion.com/LynxManifolds.asp
    http://www.barinagamotorsport.com/co...s_admision.htm
    last one has BIG list of models, think that the last time I looked the prices were also BIG
    cheers,
    Bob
    Johannesburg,South Africa
    15
    Default weber mainifolds side draught
    still available from France
    google any one of the following
    Meca Parts
    G B S Alpine
    Colombo-fr
    Was used on the 1300cc V85 alpine engines
    jimmy
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,417
    Quote Originally Posted by bob View Post
    G'day,
    cheers,
    Bob
    Do you remember how BIG the prices were?
    John
    Александър Кристоф Шанел
    bob
    bob is offline
    May 2001
    Skipton
    2,231
    G'day,
    try this one.....
    http://www.lugo.pt/images/catalogo/c...hadil_ingl.pdf
    it has prices on it, Euros aren't as as bad as they were now though, but post will put a dampener on it.
    cheers,
    Bob
    DBR
    DBR is offline
    Dec 2005
    23
    Thanks Everyone for the intel. Ross, as KB said it is a 1289 R12 Motor. Funny enough I had a a look at a Datsun 1200 manifold and wondered if it can be used. The R17 Motor Inlet Manifold also appears to be close.
    OS prices are scorching even with the puffed up Aussie Dracma. I'll just have to keep close to Ebay and wait for a 2nd hand specimen to appear.
    Life is short but you never know your luck
    Fellow Frogger! 750frog's Avatar
    Jan 2011
    Dubbo
    125
    Default datsun a series manifold on r12 head
    just wondering if the manifold was a round or oval port datsun manifold?
    4,261
    My recollection is that they are round, but if you wanted to be sure, pop in and see John Taylor at Pedders in Penrith - I'm assuming he would still be there. he used to have them cast back when he was doing a lot of stuff with Datsun 1200's.
    KB
    KB
    Auckland NZ
    380
    Yes my recollection is the same, round port manifolds
    Ross:
    1963 Renault R8
    Jan 2011
    Dubbo
    125
    Default Datsun manifolds
    Yeah Kev,
    Jeff Taylor @ JTS (brother John runs pedders in Penrith i think) has them, but not many of the round ports, he has a stack of the oval port ones.
    might have to keep my eyes peeled for one on the datsun forum.
