Connecting cables to Brake Calipers R17
    Member rique's Avatar
    Jan 2011
    Bolivia South America
    66
    Default Connecting cables to Brake Calipers R17
    Hello Folks, My R17 has a set of free cables with cylindrical connectors up front and rear left and right that according to the wiring diagram connect to the calipers. I rebuilt all four calipers and found no connectors on them or signs of any missing connectors. I have no idea where is it these cables connect to. Any ideas will be appreciated.
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Hi Rique,
    They should connect to sensors in the actual brake pads. On your car, you should have a cable on each wheel. When the brake pads are worn, the sensor will touch the disk brake and complete the circuit which will cause the brake light to illuminate in your instrument cluster.
    Matt.
    Jan 2011
    66
    Hey Matt, thanks for the help again. Guess those cables will run loose for now. My OEM pads and sensor are long gone. Do you happen to know who made them for Renault? or if they are still available.
    Regards, Enrique
    9,321
    Quote Originally Posted by rique View Post
    Regards, Enrique
    You can make your one, Rique.
    All you need to do is drill the pad material to the dpeth you want (about the bottom of the central trench) and attach a brass rivet to which you attach the wires. When the pad is worn to the set depth, the rivet will touch the disc and your warning light comes on. Not a pleasant job drilling pad material as it's toxic. Perhaps if you drill it underwater (another dangerous enterprise, perhaps use a cordless drill) it's as safe as it can be. Dispose thoughtfully of the water then.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    I thought we didn't make brake pads out of toxic material anymore so that our mechanics and DIY's could enjoy long and happy lives?
