Fuego steering wheel
Results 1 to 17 of 17
    Fellow Frogger! alpinesau's Avatar
    298
    Default Fuego steering wheel
    Can anyone tell me if a Fuego steering wheel will fit on a Virage?
    As you know the Virage/ 1.4 steering wheels deteriorate quickly in the sun, but the leather covered Fuego wheels seem to last pretty well.
    Robert
    1970 R8 Gordini R1135
    2005 Megane 225 Cup
    2008 Clio X85 Cup Racer
    2014 Megane RS275 Trophy R
    2015 Koleos Expression
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    It will fit!
    Everything from the r10 to the r 19 will fit they all have the same splines!
    I have a good one I can sell you!
    Fellow Frogger! Bolla's Avatar
    Merlbourne
    126
    Default Make a Fuego Wheel Like New
    If you get a Fuego wheel you can make it like new by buying a simple leather cover off e-bay - cost about $18 and you lace it on yourself, takes about an hour to put on (do it with the wheel off the car) and looks like a brand new cover, and feels great.
    Bolla
    85 Feugo x2
    83 Fuego (stored parts car)
    75 R12 Almost on the road!
    74 R12 Wagon undergoing restoration
    03 BMW K1200RS
    Ford Territory & Focus
    Previously
    too many Fords to list
    73 R12
    79 Virage
    8,486
    Quote Originally Posted by Bolla View Post
    ....... cost about $18 and you lace it on yourself, takes about an hour to put on (do it with the wheel off the car) and looks like a brand new cover, and feels great.
    Sounds kinky.
    Jo
    8,486
    The splines all fit but the offset may be an issue if the wheel ends up too far towards the dash
    For instance you cant put a r19 wheel on a fuego, it is too flat and will rub against the dash or not allow your fingers fit between it and the dash.
    That is the critical factor once the splines fit.
    If there is not enough clearence, it is not an issue untill you are driving like a maniac, whereby when you go to do a hand over hand, you end up grabbing the dash instead of the wheel and for a moment the driver has little contact with the steering.
    Believe me, that is one of those crap your pants moments, up there with when the brake pedal goes to the floor just before a tight corner or the chair you are about to sit on is 3 inches lower than you thought.
    Jo
    298
    Thanks all,
    I was confident in the splines being OK, but as Jo says, it's the offset that's the key issue.
    I was hoping that someone has already tried it, 'cos it saves me from re-inventing the wheel.
    U-Pull-It is open tomorrow, so I'll go for a look to see if there's anything of interest there.
    Robert
    2005 Megane 225 Cup
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    Default Fuego Wheel
    Hi Robert
    The Fuego wheel fits ok, if anything the boss of the fuego wheel is a little long and the rim of the wheel is closer to you. Its ok but u need to stretch the fingers a little to operate the headlamp/indicator/wiper switches.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    8,486
    Hi Robert
    I've been down the wrong offset wheel myself in my R12 days, where I has a nice soft R18 wheel.
    My solution was to grind off a bit of the plastic stalk cover and move the angle of the the stalk out to be the correct distance off the wheel.
    From vague memory this was a right PITA to fabricate, but worked.
    The R18 wheel was rubber all the way, where the fuego has the cast alloy boss.
    Maybe the alloy boss between the wheel and the shaft could be cut down and re welded to be the correct offset.
    Jo
    Nov 2005
    Geraldton
    1,639
    Jo sold me a Fuego wheel to fit my R12 a while back and it fits like a finger in a... Umm, its a good fit.
    The offset works well too.
    Attached Thumbnails Attached Thumbnails Fuego steering wheel-r12-steering-wheel.jpg
    Nov 2005
    Geraldton
    1,639
    Do you leave the original leathyer glove on and lace the new one over it or do you strip it down to the padding?
    P
    Merlbourne
    126
    Default Fuego Wheel cover
    I just put it over the top of the existing one which was in quite poor condition, and it a came up like new. The new cover has a small amount of foam padding in the backing which evens out any cracks etc in the original cover. Can't find the details for the one I bought, but here is something similar (although a bit more pricey) http://cgi.ebay.com.au/BLACK-LEATHER...item1e603b23ff make sure you go for the larger diameter grip version.
    Bolla
    85 Feugo x2
    03 BMW K1200RS
    Previously
    73 R12
    79 Virage
    8,486
    Alternatively, one can be made from scratch.
    With basic craft skill and a mother who can sew the two bits togeter, I replaced the entire leather cover with a new one, and lashed it on to look like a new one
    This took about three hours to template, fabricate and install but was worth it.
    Fellow Frogger! viragewagonman's Avatar
    Wagga Wagga NSW
    301
    I have 3 good Virage wheels if you are interested. Going cheep!!
    Michael
    now Renault-less
    1995 Ford Futura V8
    2011 Ssangyong Korando
    previous cars;
    81 Sno White R20TS S1
    72 Flame Orange r12 GL sedan
    78 Azure Blue Virage wagon
    75 ghost gum R16 ts
    74 Track blue r12 wagon
    74 Ghost Gum r12 wagon
    9,339
    Quote Originally Posted by viragewagonman View Post
    What is the Virage wheel any different from the 12GL for instance? I would be interested in a good one.
    The Fuego steering wheel in your picture, Jo is interesting too. Is it the same rim diameter as the R12? Any you can sell?
    Wagga Wagga NSW
    301
    This is a Virage steering wheel. Quite different from the r12 one.
    Michael
    now Renault-less
    1995 Ford Futura V8
    previous cars;
    75 ghost gum R16 ts
    9,339
    Thank you, michael, I remember now.
    298
    Michael,
    PM sent.
    Jo,
    That's nice work on the re-covering. I had one done professionally a while ago, but yours looks just as good.
    Robert
    2005 Megane 225 Cup
