R10 2 speed wipers
    Dec 2004
    757
    Default R10 2 speed wipers
    SEASONS GREETINGS ALL'
    I think it was back before the crash some one had a thread going about fitting 2 speed wipers to 8's & 10's, I was hopeing to see the finished articles pictures a bit of a how to on doing the same , Does anyone have any leads on were to find it?
    Thanks PETER.
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,896
    I always thought an R12 motor and switch did the trick? Or, get our american friends on the case as 2sp wipers were part of the US spec cars (along with dual circuit brakes).
    4,427
    Not sure if it was me or not Peter?
    I have two speed wipers fitted to my R10. It is an R12 motor and switch as the previous poster mentioned.
    The install is pretty simple, the hardest part is modifying an adapter to connect the R12 motor to the R10 arms.
    I'll try to see what I can dig out photo-wise over the next few days depending on how my xmas shopping goes, otherwise next week when I'm off work.
    KB
    Attached Thumbnails Attached Thumbnails R10 2 speed wipers-06-01-04-001.jpg   R10 2 speed wipers-06-01-04-002.jpg   R10 2 speed wipers-06-01-04-004.jpg   R10 2 speed wipers-06-01-04-007.jpg   R10 2 speed wipers-r12-wipers-001a.jpg   R10 2 speed wipers-r12-wipers-003a.jpg
    KB
    Dec 2004
    757
    Thanks KB
    Did you use the r12 loom between switch and motor or just ad the extra wires to your r10 loom? Cheers Peter.
    4,427
    Just ran some extra wires across and into the dash area. You can see the aftermarket Plug I've added in the motor photo. Somewhere I had the wiring diagram written down, but that was back in 2001/02 or something so I'd have to dig for that.
    The holes in the plate are four outside holes to mount the plate over the top of the existing motor mounting bracket; larger centre hole for the spindle to go through, then three holes to bolt the R12 motor to the plate. I even have a template for that made out of wood, but not sure how to digitise that for posting.
    cheers
    KB
    KB
