R25 steering rack leak?
Results 1 to 9 of 9
    Jerangle
    812
    Default R25 steering rack leak?
    The R25 is leaking fluid on the drivers side onto the exhaust.
    Just started , pity!
    Where in the rack is it leaking from?
    I have another rack but i can't see a seal in the rack case, so i imagine it is inside the rack?
    How much trouble to change the rack on the auto, there seems to bit a bit of stuff in the area?
    Cas
    Moderator vivid's Avatar
    parallel 43 south
    1,900
    Make sure it's not the trans hose leak.
    But I'm thinking R25v6, never owned a 4cl auto 25, did wreck one with Haakon.
    Powered by high grade French plutonium.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Its not too bad. I found the trickiest bit was a little metal shield over the universal joint at the firewall - was a right bugger to get back on...
    Pretty sure I removed the heater hoses at the firewall, and moved the transmission cooler out of the way (no need to disconnect oil lines, just the coolant hoses)
    It came out through the drivers side wheelarch ok I think once unbolted.
    Was easier than the Magna one I just did - had to lower the crossmember for that....
    May 2002
    canberra...
    8,876
    The REALLY hard part will be getting one that doesn't leak or a seal kit.
    I think these guys had seal kits at one point
    http://www.powersteeringspecialist.co.uk/
    Australia
    123
    I can do a seal kit at a VERY good price (only have 1).
    Jerangle
    812
    Default R25 power steering
    Haakon,
    was funny you mention that shield............. i suspected i would leave it off or cut it a little.
    How many hours to do the job?
    Cas
    May 2002
    canberra...
    8,876
    Stretching my memory now! Was many years ago...
    A few is the short answer Not hard, just a little fiddly.
    I actually left that shield off too... Kept meaning to replace it, never did!
    Jerangle
    812
    Default R25
    Haakon,
    great minds think alike.
    Cas
    Fellow Frogger! deja vu 25's Avatar
    Jan 2002
    657
    Yep I agree. Did it in a R25 GTX Auto. Took me a day from memory. Just a matter of getting in the tight spaces with the spanner and removing the main securing bolts (4 from memory)
    Cheers - Luke
    1990 Renault 25 V6 Baccara - Gunmetal Grey
    1974 Renault 17TS (1317) - Silver
