Fuego rear beam bending
Results 1 to 3 of 3
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Fuego rear beam bending
    I know that some have experienced problems with the Rear wheels on a Fuego going out of alignment due to the beam/stub bending.
    Having not experienced it myself, could someone confirm whether the culprit is the stub axle moving in the beam or the entire axle bending?
    I am looking into modifying the rear axle to give a little negative camber (just enough to allow for tyre deformation under corner load) and to drop the rear roll center by 20mm.
    Just an experiment really to see if I can settle the rear down a bit in transition.
    8,484
    Yes, your dscription is correct.
    I have only bent the beam in a colision, but have re located the stubs doing handbrake turns on a wet skid pan.
    Hooter is probably the guy to talk to, as he has experience in the mod.
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    ...but have re located the stubs doing handbrake turns on a wet skid pan
    So it was the stub axle moving within the housing?
