Renault 16TS Headlamps???
Results 1 to 15 of 15
    Jan 2006
    Alberta /Canada
    2
    Default Renault 16TS Headlamps???
    My father is redoing a 1970 16TS and needs both headlights can anyone help me or recomend a site for possibly finding these parts?
    Simon's Avatar
    6,161
    Silly question, but are you after the rectangular lights or the 5.75" round type?
    Also some of the rectangular lights are RHD only, so wouldnt suit your LHD car.
    Also try this site if none come up try here: http://www.r16site.com/
    Jan 2006
    Alberta /Canada
    2
    Quote Originally Posted by Simon
    they are the rectangular ones
    Tadpole ajychau's Avatar
    Oct 2005
    8
    Default Near New Lamps
    If i remember correctly, i believe a fellow called Cameron has a near new set in the boot of his trak yellow Renault 16ts..he was selling it not very long ago, that is selling the car and the boot full of spares..if you have a look in the car for sale section.
    i dont remember what his nickname is but i can tell you that his name is cameron and he is from Ringwood Vic.
    Andrew
    One Very Happy R16 Owner For Now...
    10,763
    Quote Originally Posted by Paul P
    And, being 1970, they should be Cibie not Lucas - there was an "unfortunate" period when local content dictated.......
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Moderator vivid's Avatar
    parallel 43į south
    1,880
    Hi John,
    Do you know what years in the 70's the Lucas were used on the 16?
    On my 72, one of my headlights was a Lucas I replaced with a Cibie.
    David.
    10,763
    Quote Originally Posted by vivid
    Hi John,
    David.
    Not exactly, but I bet Simon does. I recall it was around 1973-76, then the last ones made in Australia had those great Cibie biodes.
    The only thing that matters is to avoid the sealed beam horrors.
    Renault 4CV 1951
    Renault R8 1965
    Don't remind me!
    16,609
    A couple of '73s I've been raiding have the plastic bowl Lucases. The Yellow Streak '72 project has metal bowl Lucas (I worked hard to preserve the decal). Have noticed some signs of excessive heat in the plastic three-way connector plugs. I have barely looked at anything past '74 and they all seemed to be essentially the same Lucas headlights.
    It must almost be time for someone to resilver a batch of 16 bowls!
    parallel 43į south
    1,880
    Gday Addo!
    I have a metal bowl Lucas here also, must check the condition of the silver.
    I also have a bunch of Cibies here, some of which would need to be silvered. All strictly RHD I'd assume tho.
    Speaking of lights, does anyone know where I can get covers for the Cibie fog lights on the 16?
    David.
    Simon's Avatar
    6,161
    The Lucas lights were used from 1971-1975. The later black grille cars having the Cibie Kangaroo's.
    The LHD & RHD lights can be identified by the arrows on the glass under the E2 mark. Generally the Cibie lights have a double headed arrow denoting that it is for both LHD & RHD, these also have a slider to tilt the globe for LHD or RHD use. The RHD headlights have a single arrow pointing to the LHS of the car (pointing to your right arm if you are facing the glass) .
    10,763
    Thanks for the definitive answer Simon!
    Renault 4CV 1951
    Renault R8 1965
    Member reno1154's Avatar
    Jul 2004
    76
    Default 16 Lights
    DAvid,
    Autobarn will supply these covers through Cibie. They are slightly different from the originals, but I guess all things change and only a few will spot the difference.
    Happy Sixteening ... John E
    parallel 43į south
    1,880
    Thanks, found a cheap set on ebay.
    I would also like to make some headlight protectors for the 16, as the ones I will be putting on the car are perfect.
    Were there any after market 'renault' protectors sold with the car as extras? even late in the piece?
    David.
    Don't remind me!
    16,609
    May have been some mesh ones or similar. I have one grille half off a 73/74 that has neatly drilled four holes around the headlight perimeter. The other half of the grille is done similarly.
    Regards, Adam.
    Simon's Avatar
    6,161
    There were two sorts for the 12 and 16. Either a rectangular mesh version, or a custom Australian made moulded perspex version, that either screwed to the surround, or just fitted in behind the surround and over the headlight.
    There was also a flat perspex version for the 10 which was retained by the headlamp surround screws.
