ren 19 auto problem
    Fellow Frogger! dave from bendigo's Avatar
    Feb 2003
    bendigo,vic
    292
    Default ren 19 auto problem
    Hi folks, possibly have a bad problem with my r19 auto trans, I was driving into town yesterday and pulled up at the intersection, when I went to take off I had no gears, the trans was revving to about 1500-2000 before moving off very slowly and then constantly slipping, reverse still goes but forward is caput. Do people know if this is a simple low fluid or need changing of fluid, or if the trans in as I say Caput. The thing is if it is caput I had no prior warning, it had been fine until that spot, where it just stopped working. I have not driven it since, please help.
    "Some minds are like concrete...all mixed up and permanently set."
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    First thing that springs to mind is oil level, second thing is that the box has gone into "limp home" mode - electrical failure?
    Apr 2004
    Perth
    48
    Hi, in "limp mode" you could drive the car ( it is like going in 3rd gear all the time). Have it check by auto trnsm experts, but it does'nt look good.
    Cheers Greg
    NSW
    4,917
    Mine was in the limp mode when I had it and it was a broken solonoid. Quite expensive.
    Jan 2002
    2,432
    You might also want to check the fuse for the auto, you'll get a similar effect if it's blown.
