R8 Gordini help
Results 1 to 10 of 10
Thread: R8 Gordini help
    Jan 2006
    14
    Default R8 Gordini help
    Can anyone help with a wiring diagram for an 1135
    Have tried to interpolate off R8 but the colours do not work out
    Also need some geniune R8G Steel 15" rims for a ground up resto.
    Fellow Frogger! alpinesau's Avatar
    276
    Peter,
    I have a wiring diagram that I can photocopy for you.
    Send me a PM with your address, and I will post it to you.
    1970 R8 Gordini R1135
    2005 Megane 225 Cup
    2008 Clio X85 Cup Racer
    2014 Megane RS275 Trophy R
    2015 Koleos Expression
    Simon's Avatar
    6,161
    Quote Originally Posted by alpinesau
    Is this the one from the RTA book? Or did Renault actually get their act together in the end and produce their own wiring diagram?
    276
    Simon,
    It is from the RTA manual. Both Rob Sealey & I can confirm its accuracy.
    I have never seen a Renault produced wiring diagram for the 1135.
    2005 Megane 225 Cup
    Simon's Avatar
    6,161
    Yep, the RTA diagram is what I used too, it is a good diagram. Just note that it is for the earlier cars with the single driving/auxiliary light switch, not the later cars with the separate switches. But that is not a major hassle.
    Jan 2006
    14
    Default 1135 wiring diagram
    Thanks Rob and Simon
    That info. and help has been of great assistance. The project is at the frustrating stage where I am trying to get components etc ready for the shell when I get it back and around each corner I turn is a new challenge.
    I look forward to getting the diagram
    Dec 2004
    Los Angeles, CA. USA
    69
    Default Wiring
    I've just bought an R8 G "clone"... the dashboard is from a G but it's not hooked up at the moment. It's in, but not "wired". What would be my best resource for putting that together?
    THanks all...
    Simon's Avatar
    6,161
    Quote Originally Posted by Gordinowitz
    THanks all...
    Try out this web page, someone has been busy scanning the RTA manual, and has copied the 8G wiring diagram. The only thing missing is the legend from the pic detailing the components, but it should be reasonably self explanatory. Oh, and no there isn't a colour version, and there is no legend which details the actual wire colours either.
    http://pageperso.aol.fr/r8major68/annexes.htm
    Then scroll down to "R8 GORDINI : Schéma de câblage" for the zip file.
    Jun 2011
    castaic, ca usa
    1
    Default R8 gordini 1134
    I am a new member. Found your comment on a wiring diagram and was unable to find it on the web site mentioned. Any help would be appreciated. Am now restoring a l964-5(?) R8 Gordini and need to sort out a butcher job on the wiring. Thanks. Jim Degnan
    Simon's Avatar
    6,161
    Quote Originally Posted by jdegnan View Post
    Wow! A thread that survived the great fire, perhaps next time......
    Welcome aboard Jim, but that's that's a five year old link, try this one.
    http://www.r8major.fr/anx/cablager8g.htm
    As before, the RTA diagram is for the early R1135 Gordini. Your car, likely an R1134 Gordini 1100 will likely not (unless they have been retrofitted) have the driving lights and front fuel tank, and will also have a generator (unless an alternator has been retrofitted as well).
