fuego tachometer issue
    Nov 2005
    broome
    4
    Default fuego tachometer issue
    if its not one thing its another. just came from a whirlwind trup to melbourne. (by the way for those knowing i had the wiper problem, didnt get it fixed yet but rain-x sure works!).
    the tach stopped working. it seems to go up a bit at start up and floats around 1000 rpm but wont go beyond it. when the ignition is off is falls to the normal resting position. any ideas on how to fix?
    1,160
    I've had a similar issue with the 5T2, but with the Radiator dial, at times it just doesnt move up, then it suddenly goes up!
    All wiring is OK & i think its the actual dial thats getting a little stuck.
    I used a tiny amount of Silicon lubricant on it & we'll have to wait & see
    Maybe pull it out & move it up/down a few hundred times & see if that free's it up?
    Simon's Avatar
    6,162
    Quote Originally Posted by nate
    With the older Renault temp gauges, the temp gauge sender in the head has the spade terminal connection crimped onto the sender itself. With time from vibration etc, the spade terminal connector can become loose on the sender giving an intermittant contact causing the temp gauge to give erratic readings, ie fall to cold, then suddenly go back up the scale. Check to see if the male spade terminal connector is loose on the sender itself.
    The 5T2 may have a similar sender, but it could also be a later type where the male spade terminal is moulded into the top of the sender in a plastic, in which case it could be a different problem!
    Moderator vivid's Avatar
    parallel 43 south
    1,880
    nod, Aussie heat and black dash turn the needles into twisties too!
    Needles from a Commondore fit straight on, if the problem is that it is bent and touching the dial plate. Then calibrating it can be fun, but once it was done on mine (so far) all is good.
    Other fixes involve supeglue on the underside and putting them in a vice or weighted down until set hard.
    David.
    Quote Originally Posted by bloopoid
    Powered by high grade French plutonium.
    1,160
    Quote Originally Posted by Simon
    Spot on... i've done that already & removed & cleaned the contacts, however the copper wire the plug is crimped onto is pretty dull & corroded, so i'll redo the plug with a new one & crimp + solder it on (wire to plug, not solder the connector together!)
    8,397
    Default fuego fire
    Have you guys set a needle on fire??its looks realy cool (assuming you have spares)as it burns without a visible flame or smoke,and just starts bubling and distorting until it realy does look like a mini twistie.I was straitening one with just a blow drier, when it ignited.
    jo
