weber query.
Results 1 to 25 of 26
Thread: weber query.
    Dec 2004
    748
    Default weber query.
    Ive just cleaned the weber off my daughters R12 1.4 and noticed the choke butterfly on the secondary side has been removed, Can anyone tell me is there a specific reason for this or has it just been forgotten?
    secondly how long does a tadpole have to swim in the aussiefrogs pond to become a frog?
    peter .
    1965 r8 project gordini replica
    1967 r10 1289cc daily driver.
    1969 r10 doner car.
    1975 r12 1.4 sedan daughters future car.
    1975 r12 1.4 wagon open to offers.
    1975 r16tl doner car parts available.
    1980 r18 doner car parts available.
    Simon's Avatar
    6,161
    That wouldn’t be the first one I’ve seen like that, probably a PO attempt to cure some perceived problem. The original fitting screws seem peened over so would be unlikely to fall out by themselves.
    Tadpole minigordini's Avatar
    Nov 2005
    22
    As far as my understanding goes the "rating" we are given goes by number of posts and not amount of time that you hav been a member.
    wielder of the sword Australdi's Avatar
    spinsterhood
    3,410
    Icon12
    Welcome Guys!!!
    P.S. once you have made 30 posts....you can access the "secret" forums
    Aus
    Aus
    ".....the good health of a pond is held in a delicate balance. A pond's condition
    deteriorates when the bottom environment cannot support animal life.
    The bottom is the area that runs out of oxygen first, it is where the most oxygen is used........"
    '84 fuego GTX
    '87 fuego GTX
    '85 fuego GTX
    ....beginning to look a bit frightning isn't it.
    Ipswich, Queensland.
    1,888
    Not that I have done this "mod", but the I would expect the car probably works fine without it.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,382
    As starting and low speed driving only uses the primary it is quite normal not to have choke on secondary throats, this omission may be from original?
    1000+ Posts Frans's Avatar
    Auckland
    1,487
    Fordman is right. On the Renaults you have a PROGRESSIVE action twin choke Weber. That means that the 2nd choke is used only when you exceed 5o% travel on the linkage, then the 2nd opens progressively a 100% the last 50% of the travel. When the car is cold and needs choking it happens on the primary only. You are not supposed to use 2nd choke on a cold engine.
    On the older Ford V6 engines you had a SIMULTANEOUS action twin choke Weber where both chokes had choke butterflies. Both chokes worked same time, 1 feeding left bank cylinders and the other feeding right bank. So both chokes were choked.
    Frans
    Old enough to know better
    Young enough to do it anyway.
    Simon's Avatar
    6,161
    Quote Originally Posted by Frans
    A majority of the Weber equipped 12's and 16's I've seen though have butterflies to both chokes. I'm just wondering if it was a dealer fix to remove one butterfly when people flooded the things after pulling the choke right out instead of just using half choke?
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    All my past weber equipped Renaults have had two chokes.
    6,248
    Both of mine have two, too. Will its presence, or lack thereof, affect the vacuum choke release?
    Stuey
    2003 PEUGEOT 206 GTi
    5,312
    [QUOTE=Peter J Kent] secondly how long does a tadpole have to swim in the aussiefrogs pond to become a frog?
    peter .
    Ahah!
    An enquiry regarding that dark, mysterious place frequented by blackguards, ne'er-do-wells, scallywags, lost souls, and a pom or two.
    Not the place to venture on a dark night.
    Would you offer your throat to the wolf with red roses?
    If the answer is yes, get your post count past 30 and you're in.
    Bring a thick skin, a sense of humour, and your best dirty joke.
    BTW, the password is "Oscar's on the bus."
    Mike.
    Dec 2004
    748
    Default only one choke b/fly.
    Thanks all for your wealth of wisdom. Its back together and running fine.
    I was aware of progressive linkages frans hence calling it the secondary side.
    It was just the first time i had seen one removed.
    Thanks again all.
    Peter.
    120
    Quote Originally Posted by Peter J Kent
    Thanks again all.
    Peter.
    Hi Peter,
    For what its worth, I've found that the earlier Weber R12s tend to have both choke flaps, but that almost invariably those from the later 1.4 versions only have the one on the primary. As Simon suggested, it may have been a dealer mod, as I have found no sign of butchery as one might expect from a PO etc trying to do a fix. As a factory mod by Renault & Weber it would save money - perhaps it was .
    Renpete
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    Many progressive choke Webers had only one barrel with choke.
    The second barrel does not open at starting revs so no need for choke flap.
    28/36 DCD from GT Cortina was like this in most versions.
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Perth Western Australia
    2,678
    Default Weber choke..
    Quote Originally Posted by Westair
    I removed the secondary choke flap on my Weber 504 conversion in order to gain those elusive KW's. Only joking !
    I had to convert the Weber to manual choke, this meant doing away with the fast idle linkage. I had visions of being surrounded in black smoke with a two choke cold startup.
    Even with the idle jet cut back in size cold starts are no problem. Well maybe a little "Fred Astaire" work with the throttle now and then.
    Westy, The Weber DCD I have in store,[wrapped in swaddling cloth], doesn't have butterfly chokes. It uses an enrichening device for cold starts.
    Member leigh's Avatar
    Ballarat
    74
    Icon11 Choked
    Just waying in on the end of a thread... I have had the pleasure of playing with a few DIR 32's in the past but haven't come across one with the flap missing.
    But this is not the real reason why I write this reply - in truth, I am just trying to get my post count up. I used to be known as a Fellow Frogger but now? Can't help being a little offended by being called a 'member'.
    Might have to start a Catch up to Europa & Kenfuego thread. Might take a while to think up 2000+ posts, even if they are mindless.
    Ballarat
    74
    Default Correction
    That would be weighing in not waying in.
    One more post closer to global domination!
    16,367
    I doubt it's been removed from the secondary side of the carby .... Due to the simple fact, it's not required there ... After all who starts a car cold with full choke and the 2nd barrel of the carby wide open
    It probably hasn't been there since the car left the factory !!
    PS: Leigh, you'll just have to come online more often
    Ballarat
    74
    Icon10
    Yeah I know, but the #58 hasto count for something.
    Saw your post about slugomatics... Distinctly remeber you saying that you liked my Goon (Laguna)
    (and another post - I'm on a roll)
    Ballarat
    74
    even if my spelling doesn't
    16,367
    Quote Originally Posted by leigh
    I do like Laguna's .... Can I have the seats out of yours
    6,248
    Trouble is, Leigh, that when you get to 30 posts, you're called a 'complete member'.
    Ballarat
    74
    Icon7 Sometimes the truth hurts
    Big member?
    Jan 2002
    2,432
    We are mere minnows in the Aussiefrogs sea of postings. Danielsydney should be your target!
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    Cross Member?
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
