R10 front panel
Thread: R10 front panel
    Member julian's Avatar
    Aug 2003
    102
    Default R10 front panel
    Hey everbody yet again.
    I am having a few problems removing the front panel of my R10 (the panel in which the headlights sit). I can get the side mudguards and the spare wheel retainer off but the front is bothering me. Have I missed a few important bolts, or are they tacked in at the factory?
    It is a square eye 69 R10.
    Thanks all,
    Julian
    Simon's Avatar
    6,162
    It is spot welded at the factory, note the spot welds in the panel adjacent to the headlights and across the boot floor.
    Aug 2003
    102
    In that case, what is the best way to remove and replace this panel?
    I have access to most tools.
    Julian
    Simon's Avatar
    6,162
    Quote Originally Posted by julian
    Julian
    To remove it nicely:
    Spot weld drill or power hacksaw/gas axe then angle grinder to remove the nasty bits, then dress the edges where the new panel will be welded to.
    1000+ Posts Renomad's Avatar
    Jul 2003
    1,197
    Quote Originally Posted by Simon
    My brother inlaw and myself did this job to my R10 many years ago, but we were a bit more brutal. We wedged a big screw driver in the gap where the panels joined and popped the spot welds apart. It was a realitively simple process, but it did require a some panel beating to straighten out the edges afterwoulds!
    Cheers Renomad
    "Today's mighty oak, is just yesterdays nut that held it's ground"
    Current frogs, Dad's R19 & Dad's Scenic.
    Past frogs, R12 Wagon X2, R12GL, Fuego X2, R10 X2, R8 X.5!
