Fuego bodykits
Results 1 to 25 of 47
Thread: Fuego bodykits
    Nov 2005
    Lismore
    20
    Icon5 Fuego bodykits
    i have a prestine 1985 renault fuego, and am looking to do it up. Does anyone knoe where i can get bodykits/spoilers or any external excesories
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Noooooo, don't do it!
    But if you have to, I think "gunnawanna" might know of some good Fuego bits...
    Oct 2002
    Melbourne Victoria
    11,777
    Default Fuego - recommend not fitting rear spoiler.
    Quote Originally Posted by HoldenFreak
    Not sure what you mean by body kits. Mistarenno is in the process of trying to bring in a new front bumper from France via Renault normal suppliers, you can re fibreglass and refinish old bumpers. There are some NOS tail lamp assemblies about and they occasionally come up on Ebay.
    Myself I would not fit a rear spoiler as it just adds weight on the hatch cover frame, which is already probably slightly weakened by water seaping through cracked sealant (very light metal frame inside the rubber moulding) and the hatch lock platforms get weak if rusted and virtually impossible to fix/weld back if they break off - the extra weight just flexes the weak weld area.
    Door scratch protectors may be available somewhere, but replacements usually come from Pick a Part cars. The rubber to accentuate the sweep line should be able to be sourced from auto shops or wrecked Fuegos.
    Don't know where you would get a new or newer grille, and the plastic chrome strip at the bottom of the grille is becoming hard to find in good condition.
    Metal strips and clips usually come from wrecked Fuegos, but you might just find some lying around at a former Renault part suppliers - ask.
    Hope this helps a little.
    Moderator vivid's Avatar
    parallel 43° south
    1,880
    Ill swap you my Fuego for the pristine one you can put a body kit on.
    David
    Powered by high grade French plutonium.
    Nov 2005
    Lismore
    20
    thanx im also looking for a repair manual... does anyone have one??
    Jul 2004
    CLARE SA
    2,324
    Ps, new name please!
    ed ge
    we only abuse fraud & holding here.
    parallel 43° south
    1,880
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Yeah, I must echo the sentiments of the others..Don't Do It...
    The Fuego has unusual bumper lines that just don't seem to suit a body kit..
    You can get Fuego GTA bumpers (there is a set on EBAY at the moment) that don't use the bumper line - for a 'wrap around look' but even they look a little 'wierd' IMHO...
    FWIW - Why do you want to fit spoilers?
    I presume it is just to improve the looks?
    If you lower it slightly and fit some nice wheels, it will look great and handle even better
    Member Zareh's Avatar
    56
    One of the FUEGO owners on my website got some from france:
    http://www.clanmedia.com/fuego/index.cfm?pid=71&uid=95
    I'll try to get the details for you.
    Zareh
    parallel 43° south
    1,880
    umm....
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by vivid
    umm....
    yip...
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    How about a photo of your car?
    Warren
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Don't do it!!! Simple as that.
    ...If your Fuego could it would be crying tears of oil....sacre bluur They burnt witches in the dark ages and murderers used to hang, lucky for you ricers don't get the same treatment
    Keep the ricin' for the Jap/Korean boost cruise scene.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Christchurch, New Zealand
    105
    Ebay has parts for the South American phase 3 GTA Max but only the radiator grille will just bolt on. Fitting both front and rear bumpers would require cutting off metal from both front and rear panels, and you can be guaranteed that mounting them would be quite a bit of work. As for a spoiler, big ones just look stupid.
    The best way to sport them up is a good set of (non Chrome!) 16 inch alloy wheels, and i've lowered my Turbo slightly at the front - She looks awesome!!! (my other 2 are in original condition).
    8,396
    I must admit to pondering about body work to the fuego.Based on every kit i've seen,particularly from argentina, I'd have to sat that they look like crap, and remind me of the body work that guys would do to their toranas and HQ's in the seventies.I'm thinking of opening up the vents in the turbo bonet,and constructing an intake off that.If I could hide the spare a bit with a skirt,that would be cool, too,but all that other crap like side skirts and rear quarter pannels...YUCK...
    Jo
    Ps I think graphics would look cool on a fuego
    Jan 2005
    Perth
    558
    Keep it basically stock-spend your money on wheels and the mechanicals.
    Most of the Argentine stuff is for competetion cars that is light and relatively cheaply replaced.
    Unless you are racing most of the aero-dynamic bits are definitely not required on a road car.
    1972 VW Kombi
    Harold Ganeen.
    Feb 2003
    576
    Quote Originally Posted by Zareh
    Zareh
    Hmm I think he forgot the wide wheels....
    2013 Grand Kangoo
    2011 Megane 3 RS
    2001 Clio Sport 172 (23/85)
    1997 Spider (No. 652)
    1988 5 GT Turbo Phase II
    1968 10
    parallel 43° south
    1,880
    They dont exactly fill out the arches do they?
    David.
    Oct 2002
    Melbourne Victoria
    11,777
    Icon7 While I like the standard look..
    Most of you are aware that I try to keep my own cars standard and as original as possible, my personal credo is that any owner is entitled to do what they like with the car - thats part of being an owner.
    Also it keeps another Fuego around and running and one day someone may just want to restore it to its original configuration.
    Just as there are good and bad restorations, there are good and bad styling changes.
    But that's life and its your choice, I might prefer original and recommend against modification but in the end its your car - I say enjoy your car and take pride in it.
    If some don't like the finished product well that's life too, now wheres that tough tittie emoticon
    Nov 2005
    Lismore
    20
    Default thanx
    thanx for all the tips.... on the asumption that i am going to keep it original condition, i still need an original front spoiler... the one with the foglights..... mines in need of some maintenence and as i am a busy man i dont have the time to repair it and would rather replace it!
    8,396
    Yours and everyone elses it seems.
    Jo
    Nov 2005
    Lismore
    20
    yeh only thing is, i caused the damage...... broke the left hand floodlight and broke a chunk off the corner of the spoiler!!!!!!! GUTTED!!!!
    8,396
    Still got the chunk?An easy repair being fibreglass.
    Jo
    Nov 2005
    Lismore
    20
    no unfornatly not!!!!u dont know another way??
    parallel 43° south
    1,880
    Could use resin to fill it, and paint the whole thing.
    There should be some old threads on painting fuego bumpers.
    David.
