Laguna Head gasket thread
Results 1 to 12 of 12
    1000+ Posts BogMaster's Avatar
    Canberra,act,australia
    1,457
    Default Laguna Head gasket thread
    I guess that thread may have been pulled because of defamation issues regarding repairer/s.
    I'm wondering if the head gasket thing was resolved and the car repaired for less than the mega dollars quoted for an engine rebuild.
    The problem was interesting - do the things require a rebuild if you blow the headgasket or not?
    Woo Hoo Honi ko'u 'elemu (Hawaiian)
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Quote Originally Posted by BogMaster
    I don't believe they do, unless there is a root cause of the gasket failure that requires further work. And I guess with these things, you always need to balance up the cost - maybe it's worth a rebuild due to the amount of labour required just to do the head gaskets.
    To replace the rear head gasket, you do need to pull the motor/gearbox unit out of the car. Front head gasket can be changed in-situ.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Europa and Bogmaster,
    Yes you would peobably have to remove the engine to do the rear h/g in a Laguna with transverse mounted engine but a 604/R30/Volvo and any normal alignment of the engine wouldn't require such.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Moderator vivid's Avatar
    parallel 43° south
    1,880
    You are correct BogMaster, we had complaints, and unsubstantiated claims.. so the thread was pulled.... probably later than it should have.
    David.
    Powered by high grade French plutonium.
    Jan 2002
    2,432
    Quote Originally Posted by HONG KONG PUGGY
    No probably about it mate, the Renault Laguna MR technical manual says it has to be done.
    Nov 2002
    2,755
    Quote Originally Posted by Europa
    Figured as much, well that'd account for a fair fee then.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    1,457
    But nothing like the quoted rebuild costs.
    Jan 2002
    2,432
    I believe the price advised on the forum was wrong. If you would like to hear the real quote, I suggest you contact Auto Paris.
    parallel 43° south
    1,880
    I beleive it wasn't the only questionable statement made by that particular member... without naming names. Even so, should be very careful about what sort of accusations you start throwing around in a public forum.
    Lets not have this thread binned to... easy goes!
    David.
    1,457
    I think there is something weird about the whole business from go to woe. I don't see Paul as someone who would advise a rebuild if it wasn't necessary.
    What is clear is that the car in question has given the owner a considerable amout of grief - there is another thread here about a gearbox rebuild.
    Jan 2002
    2,432
    Therein lies a clue as to the explanation of the total $....
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    WORD TO THE WISE, LESSON TO THE LEARNED
    Don't believe everything you read in the papers ( or see on the 'net)
    Mike
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
