R12 seat belts
Results 1 to 15 of 15
Thread: R12 seat belts
    6,668
    R12 seat belts
    Does anyone know how to remove the front inertia reel belts from a '76 R12? Where are the bolt/nut heads? Inside the car's sill, or do the plastic covers come off the reel to reveal the nuts?
    Stuey
    2003 PEUGEOT 206 GTi
    Aug 2002
    27
    Rip off the alloy strips from the door sill, pull down the carpet, bolts are at either side of the reel housing. The reel bolts to the side sill.
    Aug 2002
    27
    The upper mounting bolt is under the plastic cover, push it upwards to get it off.
    Brisbane/Australia
    2,168
    Don't know abouth an 86 model, my 80 model has two bolts either side of the reel-box, under the carpet.
    I think the 86 model was Aussie-assembled so could use locally sourced belts and be different.
    Ren
    cheers!
    Simon's Avatar
    6,203
    REN TIN TIN:
    Ren
    cheers!
    Hmm, do tell more about this Aussie assembled 1986 model???
    Actually all 12's and Virages originally sold in AUS were Aussie assembled, apart from this mysterious '86 model that I've never heard about :-).
    All the 12's onwards from Jan 1975 and Virages to the end have the same system of bolting the inertia reel to the sill. The later 12 1.4's and Virages with cut pile carpet have the bolts covered with plastic as the carpet doesn't extend up the sills.
    Simon
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    6,668
    Thanks. I need to replace them, hence the question. The belts have gone all stiff and faded.
    Stuey
    Fellow Frogger! Virage Racer's Avatar
    Jun 2002
    Perth Western Australia
    152
    Hi Stuey
    What are you going to replace them with ... or are you going to have the webbing replaced by those guys in Welshpool who are the only WA police-approved belt repairer?
    Keith
    1976 12 Gordini Faker
    WA's only 12 in regular club comp
    Simon's Avatar
    6,203
    They are produced, they seem to be a fairly generic design. R12 ones were listed in a seat belt replacement catalogue in one of the big auto accessory places here.
    Simon
    1963 Renault R4 Van
    1964 Renault R4
    6,668
    I'd seen a listing on the back of a Securon (brand) seat belt box in Marlows, for another car. However, on closer inspection today, I noticed they only list static belts. I wouldn't worry about myself, but I occasionally carry my youngsters in their booster seats, and the belts are a bit tired to be safe.
    Stuey
    Jun 2002
    152
    Following Simon's tip, I'd try Repco and Coventry's to check out alternatives. You can also ring Klippan Safety Products direct - 1 800 804 588
    Otherwise, try Aircraft Upholstery Service, 93A Leach Highway Kewdale for re-webbing - Ph. 9353 3932
    Keith
    11,188
    Virage Racer:
    Many thanks for this information - just what I needed as well, as it happens.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Brisbane/Australia
    2,168
    Simon,
    Okay, I stuffed up; the 86 should have been 76 (although 12's were still being built in 86 in South America, Turkey and possibly other places).
    And yes, the 80 Virage didn't have carpet extending up the sills originally but the one I was looking at had been recarpeted with the earlier type carpet that extends up the inner sills. (I think the earlier carpet that covers the sills looks more 'finished'). The Virage had black vinyl glued to the inner sill.
    I know the 76 plated 12’s were Aussie assembled but wasn’t sure about the 1980 type as it would have been around this time or slightly after when Renault Australia pulled the plug. If you say all 12’s and Virages were assembled here, I bow to your greater knowledge.
    Ren
    cheers!
    Jun 2002
    152
    This Aussie assembly thing is a bit weird. Although my R12 Virage (originally with 1.4 motor) was plated 1976, the seat belt tags say 1978!
    Keith
    Jun 2002
    396
    Stuey:
    Securon belts are really dodgy looking garbage. Unfortunately many auto parts stores (like many Repco branches) only stock them and not the much superior Klippan products.
    Klippan seem to be the best belts generally available. I just bought 2 inertia reel Klippan belts for the front of my 505. They cost $90 each.
    Dave
    6,668
    fiveohs
    Dave
    Thanks Dave. I hadn't actually looked in the boxes. (How come my quotes aren't in bold?)
    Stuey
