Fuego KYB Shocks
Results 1 to 11 of 11
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    Default Fuego KYB Shocks
    KYB Gas Shock Parts Nos. Prices are US$
    Renault Fuego 1981 - 1983 343180 $21.78
    Trim: ALL Specs: Renault Fuego KYB GR-2 Gas Shock, REAR - KYB GR2 Shock
    Renault Fuego 1982 - 1985 341047 $36.90
    Trim: ALL Specs: Renault Fuego KYB GR-2 Gas Shock, FRONT - KYB GR2 Shock
    Renault Fuego 1982 - 1985 343180 $21.78
    Renault Fuego 1984 - 1986 343180 $21.78
    Renault Fuego 1984 - 1986 341047 $36.90
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Member DragoN's Avatar
    46
    Do u know if there is a dealer in Melb? i had a look at there web page and could not find any info about overseas dealers? Or am i going to have to import some if i want them?
    Thanks for the post. i was getting scared as someone said konis no longer made them and they were the only ones i knew that made shocks for fuegos
    Simon's Avatar
    6,174
    Try contacting them direct to find out who the resellers are:
    http://www.kyb.com.au/
    Toll free 1300 554 059
    Just FYI, KYB is not the same as Koni, but they are known as a quality shocker nonetheless.
    Oct 2002
    Melbourne Victoria
    11,906
    Default Fuego Front & Rear shock absorbers
    Standard New Fuego replacement shock absorbers Front and Rear are available from Caravelle. Also.
    Ken Bailey has been working in with Mistarenno and a few others who are doing a R25 conversion for those that want a stiffer front suspension setup. (Involves quite a few changes)
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Westair
    Note the word 'ALL SPECS'...
    How the frick can you make a damper for ALL SPECS when Fuego's came out with everything from a softly sprung 1.4 Litre TL through to the firmer sprung 2.0L GTX which weighs 250lb more (most of it infront of the front axles)
    The aftermarket dampers seem to be a 'middle of the road' damper and when you fit them to a 2.0L Fuego, they feel floaty and jittery and just generaly under damped...
    Combine the above problems with a bigger wheel/tyre combo (more unsprung weight) and the problems just get worse...
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Off topic : Years ago, I fitted KYB Gas shocks to my R17, and they were hard as nails, really good stuff. Unfortunately, one of the rear shocks sheared it's bottom mounting and I was unable to source them again - so a set of standard oils went in as a temporary measure. With stiff front and soft rear suspension, it was like being in a rowboat on a 1 metre swell during hard acceleration, lots of pitching.
    Hopefully the KYB spec above is set for the heaviest Fuego front end (turbo diesel perhaps?)
    Simon's Avatar
    6,174
    Quote Originally Posted by mistareno
    Renault must have worked their usual magic with the OE shocks :-). They only list two sorts which are equivalent for the TL through to the GTX.
    7700686594 or 7700704662 for all Fuego's, including 762 (AUS) spec Fuego's up to oval plate 35500.
    and
    7700681869 for certain versions of the R1360, R1362 and R1363 (including 762 spec from 35501 onwards.).
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Simon
    and
    I'll have to take your word for it as I don't have the original 1980's micrfische's but I was sure it was Ken from Caravelle that looked up the original microfische for me (after I put in a new set of dampers and it felt terrible comared to the 180k dampers).
    From memory there were 7 different dampers across the model run (not including America)
    I'm pretty sure he also said that Renault will now only supply 1 replacement damper to suit every Fuego...
    I think it's called cost consolidation...
    Simon's Avatar
    6,174
    You don't have to, the details were ripped from the pieces d'origine parts catalogue, so it is the Renault Boffins that have spoken. The only number I didn't list was the shocker for the early R1360. The remainder are as quoted.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Just out of curiosity, what year is that catalogue?
    Oct 2002
    Melbourne Victoria
    11,906
    Default Fische reader and Fisches
    Richard
    I have a Fische reader and fisches for the Fuego etc if you want to borrow them at any time - I just don't have the space to have the reader out of its storage area.
    Love to get something capable of scanning a fische directly into the computer for easier searching.
