Carpets for a 16?
    Dec 2004
    53
    Default Carpets for a 16?
    hi guys
    have tried Moulded Car Carpets here in WA, with no luck, they list only the 12 and Virage ... is there anyone in OZ who stocks carpets for a '76 16TS? Black of course!!
    cheers f.
    Simon's Avatar
    6,172
    From memory there are not too many complex bumps in the carpet of a 16, certainly not the front set. Id say an auto trimmer would be able to knock up a decent set fairly quickly and overlock the edges.
    For anything complex, such as bumps or footwells, make up a mould (using builders spray foam etc.) then apply a heat gun to the back of the carpet over the mould (heat gun set to below singe and burn) pressing the carpet to conform to shape. But Im sure the 16 would be a simpler operation, especially for a decent auto trimmer.
    Dec 2004
    53
    Quote Originally Posted by Simon
    thanks Simon
    I'll start chasing up auto trimmers ... as you said .. it can't be that hard!!
    chssre f.
    Moderator vivid's Avatar
    parallel 43 south
    1,882
    Quote Originally Posted by Trackyellow
    thanks Simon
    chssre f.
    Agreed, no bumps or complications.. I have a set out of the car, looks very straight forward, do you have existing carpets to go on? I was planning on doing some measurements and diagrams to post up anyway.
    Will be making myself up a couple of sets sometime down the track.
    David.
    Powered by high grade French plutonium.
    Dec 2004
    53
    Quote Originally Posted by vivid
    David.
    hi david
    yep, have two rather worn sets ....
    oh, and when i went to grab the camera yesterday for those photos I promised, flat batteries! so will get you the photos later this week ...
    cheers f.
    parallel 43 south
    1,882
    No probs mate,
    No rush, when your ready. Put up a WTD post for the R16 doorlocking bit, maybe someone still has a door salvagable for parts. If I come across one in Melb, Ill let you know.
    Incidently how are the rear interiour plastic bits inside the hatch? I have 1 good set for 3 cars.
    David.
