fuego engine mount
Results 1 to 15 of 15
    8,466
    Default fuego engine mount
    Just cut my first thread ever,whilst fabricating up a MistaReno patented front mount,or my version of it.Thanks for sharing your design.There is a vibration being transmitted now,but as a male,I find it quite pleasurable.My car realy does give me the horn now.
    Jo
    8,466
    Quote Originally Posted by jo proffi
    Jo
    that vibration was too much, as something behind the dash would resonate between exactly 2 to 3000 rpm.Today I removed the creation and reinstalled with 2 strips of 1mm(ish) rubber mat between the body and the body-bracket,and rubber washers for the bolts that hold the bracket to the body. I drilled out a suspention bush washer, and placed an old bush on the drop link,but didn't have time to find another set for the bottom side.will do that another time. By decoupling the bracket to the body,a lot of the vibration has gone,but the mount still does the trick.I need not be so careful when coming quick off the throttle,like in traffic.I could previously feel the movement in the drive train through the gear stick, but that has all but gone now.
    Jo
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    Can't you get a standard mount?
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    You probably made it too short (or to long) and when it is tightened up it takes to much load (either lifting the engine up or pulling it down)
    I made sure that the mount I made was loadless when fully tightened.
    Also be sure that the bolt that goes through the bush is a very loose fit.
    I used an old rather worn sway bar bush and the bolt was actually completely free and didn't really touch the sides from memory.
    There was certainly no more vibration than the original design...
    5 years and still no issues
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,918
    Maybe its just me, but I was perfectly happy with the stock mount. Tossed a $20 newbie in, and forgot about it. Never had any real longevity issues with it.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Have a look at the front mount on my car (photo taken quite some time ago by Ken Fuego)
    Fuego Front Mount
    It is not 'loaded' at all...
    Hakkon, the front mount on Fuego's are rather weak and fail reguarly when driven hard and its failure can lead to failures of the other engine and gearbox mounts.
    I've never had a mount break on my car in 150K which is doing Ok for a Fuego (especially considering the driving style I often employ)
    Many Fuego owners also complain about axle tramp if they get wheel spin etc, but I haven't had any issues when at DECA or being driven hard on the road. It spins but still puts the power down smoothly. I think the better control of movement offered helps...
    May 2002
    canberra...
    8,918
    I know all about its supposed flaws, having had 2 Fuegos. Both of them were driven plenty hard enough, but just never had one fail.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Haakon
    I must admit, I never have had one knowingly fail either but when I removed the one from my car (that looked Ok) it fell apart as soon as I unbolted everything...
    They are not designed to take any static load, just to restrict movement, however the non-genuine ones seem to be alot more fragile than the original units.
    I suppose the good thing is that they fail 'safe' in that they stay together even when the rubber tears (albeit allowing even more movement than normal)
    Horsham, Vic
    36
    I've had two fail on me, one every coupld of years and I'm no Evil Kneivel, repalcing them, it even feels pretty fragile, like the ballistics gel in Mythbusters. To scared to look again after going through a massive pothole the other weekend.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Oh yeah, forgot to mention (and it can't be seen in the pictures)
    There is tubular sleeve around the bolt that goes through the bush (between the 2 side 'legs' ) to prevent the bush being squashed when you tighten the nut. It also ensures that the nut tightens up by a proper metal on metal contact.
    It is hard to say from the photo, but it looks like you just tightened a bolt up without the sleeve.
    This means that the bush will have no way of moving freely (and will transmit alot more vibration) and the nut will probably come loose also...
    You may have done this but it is hard to say...
    8,466
    If I had any faith in the OE mount,I'd not be doing this.I think that the front bush is an exelent indicator of the state of the other mounts, as if they are a bit sus, the front will go ,for sure.I tend to go through mounts,and luckilly have not suffered any major consiquences, but am keen not to either!
    Mr Reno,I''m sure you are right about the loading bit.The bush I used was from the control arm side of a fuego droplink, and has a metal sleeve already.The bolt is the same size bolt, as the damper/sway bar bolt.Had to drill out the mount a bit.I have washers from the end of the drive shafts,to fit on either side of the bush but ran out of time re-assembling, and left them (and a few others) out. This meant that the bolt is reaching the end of its thread with maybe 10mm to go before it causes the bracket to bite into the bush.
    the rubber de-coupling has made a huge difference, but I think I'll try again tomorrow,with the other side of the droplink, the non sleaved side,giving it a bit more complience.
    The difference it has made to the car is quite amazing.might even think about a rolling first gear start.
    Jo
    Jo
    Moderator vivid's Avatar
    parallel 43 south
    1,890
    Jo
    Other mounts aside, I also gave up on replacing front mounts with OEMs the last one I put in lasted 1 month! AND I must mention, this is on brand new rear engine mounts.
    Maybe it depends on the engine? My understanding was that the original design transmitted too much vibration through the car, so they removed one.
    Ill have to take a photo of the broken mount, its floating in the middle, but not going anywhere. Its like there is too much upward force.
    David.
    Powered by high grade French plutonium.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    Jo
    Shhesesh, If you are using the top mount I'm suprised everyting in the car doesn't vibrate
    Yeah, use the bottom mount (new or slightly worn) and sleeve the bolt so that the brackets 'just' touch the bush when the nut is tightened (no side pressure is required)...
    You can adjust the plate that bolts to the body up and down and the drop link fore and aft (sloted hole from memory) to ensure that there is no static load on the bush.
    It does make a huge difference to the feel of the car, as it does't feel like the engine is floating on a bowl of jelly when you accelerate or brake...
    Oct 2002
    Melbourne Victoria
    12,477
    Default Time to set the design
    Richard
    Probably time to spend five minutes to inspect the mount out of the car and at the same time do a quick sketch with dimensions - that along with the photo will be enough for any budding engineer to fit this vast improved engine stabiliser!
    Ken
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by Kenfuego
    Richard
    Ken
    Yeah,
    I've gotta do a Cam Belt on my holidays so I might take the mount off and measure everything up.
    If I'm feeling motivated I might even make a new one up so I can take some photos as a step by step by guide...
    Jo, I wouldn't use that rubber sheet between things that are meant to be tight as it will allow small amounts of movement which will quite quickly lead to more and more movement, lose nuts etc..
    Also, there is supposed to be a step on the tapped thread (and a washer under that step)...
