fuego gearshifts
Results 1 to 25 of 30
    May 2001
    New Zealand
    314
    fuego gearshifts
    Hey guys,
    just a point for any Fuego owners out there. I am installing a fuego box in my R17 and noticed that of the two gearshift levers, one of them slides in and out of a rubber bush. This bush was totally floggged out and no doubt affected the feel of the gearbox, let alone it's movement. I wwas told abot $35 NZ for a new rubber bush from France- 3wks. A suspension specialist gave me a suspension bush for FREE. I took in the original and he matched it to one on the shelf- it was a very common bush.
    I realise this isn't exactly earth shattering- but anything that will improve a fuego box has got to be good!!
    Cheers Ben
    Fellow Frogger! frogs4ever's Avatar
    Jan 2003
    Tasmania
    392
    Would this be a very difficult repair with the gearbox in the car?
    I'm likely to be finalazing purchase of a Fuego on the weekend. Not a bad drive except for spongy brakes (possibly needs bleeding), and porridge stiring gearshift.
    2004 Clio Expression Verve 4sp auto -
    1984 Fuego GTX 5 speed (now a write off) -
    1976 504 GL auto (sold)
    French cars, Australian wine.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    Ken Bailey at Carrevelle has these bushes made from nylon for bugger all, and they make the gearshift precise and nicely notchy. Add a new clutch cable for a light pedal if needed, and they are a delight to use.
    <small>[ 31 October 2003, 04:02 PM: Message edited by: Haakon ]</small>
    Jan 2003
    Tasmania
    392
    Thank's Haakon,
    When I pickup the Fuego, if I find that the bush is stuffed, I'll contact Carravelle.
    Are they difficult to fit?
    May 2002
    canberra...
    8,752
    Nah, very easy push fit type deal. a bit of soap and hot water aids things if I remember correctly...
    Jan 2003
    Tasmania
    392
    Good news, thanks Haakon.
    Jan 2003
    Tasmania
    392
    Update:
    The Fuego is now mine!
    I've ordered a new gear selector bush (along with several other unrelated bits and pieces).
    Now that the car is in my hot little hands, I've had a chance to have a slightly more thorough look underneath, and in the process have had a closer look at the gear selector linkages.
    The rubber bush at the back of the selector shaft is indead completely stuffed, but that will be replaced by the nylon one which is on order, and I can easily see that it will make a big difference to the gear shift feel.
    But of rather more concern, I have also discovered that at the point where the selector shaft goes into the back of the gearbox, the shaft has quite a bit of play (at least 1mm side to side). I'm presuming that this is as a result of wear in a selector shaft bush in the gearbox casing. Wouldn't this amount of wear allow the gearbox oil to just flow straight out the back of the box where the selector shaft enters? Especially under accelleration when the G forces involved will cause oil to surge to the back of the box? Or is there some other unseen seal or something else which prevents this from happening?
    If my concerns about oil loss by this means are legitimate, is there anything that can be done about it, preferably without removeing the gearbox from the car and completely overhaulling it?
    Sorry for all the questions, I'm still waiting on a Haynes manual.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    Hi Ben
    What are you using for gearbox mounts? The Fuego gearbox has one side mount and the R17 gearbox is mounted at the rear. The reason I ask is cause I'm going to fit a R18 gearbox to a R12 wagon and was wondering how you were going to attach the gearbox mount to the chassis. I have a few ideas but nothing concrete yet.
    Regards Col.
    Brisbane/Australia
    2,051
    Icon6
    Hello Col,
    The R18 gearbox has side mounts whereas the R12 has the mount at the rear as you said. You would have to make some brackets to go from the R12 gearbox mounts (the rubber ones) to the side mounts of the 395 box. It's not really that difficult if you've got an angle grinder and a welder.
    What are you going to do about driveshafts? The 395 (R18) gearbox is wider than the 352 box so you can't use the original driveshafts.
    I'm told that you can transfer the diff from the 352 gearbox into the 395 gearbox to reduce the width and use the original driveshafts but haven't tried it (yet). The other option is to use shortened R12 shafts, if you can find them.
    Ren
    12,256
    how much would it cost to get someone to shorten some drive shafts ?
    there would be places around that would be able to do it
    i know daniel engineering in wollongong would do it
    you could nearly even do it yourself but would be best to get someone who does it all the time to do it and of course they would be true and balanced
    1 x '98 306 GTi6
    May 2001
    New Zealand
    314
    Hi Guys,
    umm, the gearbox is mounted on the sides - a mate of mine helped me out- he's an engineer. It now has two mounts on the side of the box that bolt to the chasis rails- that was the easy part- it was much harder to sort out a workable engine mount for the 1647cc motor...
    The shortened driveshafts- Dave Cavanagh did that for me- and they have worked fine for me. I also added negative camber on the front though- which would help any possible binding of the driveshafts that some warned me about...
    The 5spd box is really worthwhile on the 17, gives it so much more cruising 'legs' , it's just not funny!
    Any other queries re: the conversion feel free to ask I'll answer them as best I can..
    Ben
    Jan 2003
    Tasmania
    392
    My Fuego's sloppy gearshift has become rather worse than just sloppy....
    See my Fueogo weblog for details:
    Fuego frogs4ever weblog
    May 2002
    canberra...
    8,752
    That happened to me too!! Mine was the metal ball joint on the selector shaft. It happened on Victoria st in Melbourne - took off from the lights and when I went to grab second, it let go and went all floppy leaving me in neutral!
    The amazing thing is that I managed to keep up the momentum and coast across 2 lanes and into a convenient parking spot on the side. It had tall gutters and I still had enough speed to pop the left front wheel up onto the kerb.
    It was right outside a florist shop and all those years of buying flowers for my girlfriend paid off (well, apart from all the other ways...), for I knew that Gerbras are sold with long bits of wire to support the stems. Ducked into the shop, got some wires, crawled underneath the car on the boot mat, wired up the linkage and off I went. Whole thing took 15 minutes
    Jan 2003
    Tasmania
    392
    Good to know I'm not alone in this Haakon.
    It was night, I had my good clothes on and everywhere was shut, so I didn't have much of a go at fixing it on the spot.
    How did you fix yours permanently? ... or did you just leave it like that?
    I'm about to ring Dave at French Connection to see if he's go some bits to reco the whole linkage mechanism properly.
    Doug.
    May 2002
    canberra...
    8,752
    I actually left it wired up for about 3 weeks!! It worked really well, but in the end when I finally got off my butt and fixed it I just used a good linkage from a spare parts car I had. Dave should have a good linkage for you cheap. Very easy to fix and the sort of thing that only needs doing every 10 years or so
    Jan 2003
    Tasmania
    392
    Latest Fuego gift shift saga update....
    May 2002
    canberra...
    8,752
    Ah yes - the hoon factor. Lost count of the times idiots in ******mobiles wanted to race me in my Fuegos. Dont understand it, I didnt think they looked that fast.
    I suspect I have a good linkage in my collection of bits, yours for the price of freight - I will have a look at it later this week. I also have a gearbox with only 130K km on it that didnt leak at all. It got replaced due to its owner driving on a dud clutch for too long and it killed 2nd synchro. I was going to keep it for NG spares for my R25 box, but for the rear casing we may be able to strike a deal...
    If the front metal ball joint is completly buggered, I reckon getting a second link and welding the rear joint that uses the nylon bush for a push on fit at the front as well would be the go. The R25 uses this setup.
    May 2002
    canberra...
    8,752
    p.s. DONT GIVE UP ON THE FUEGO!! Its just one of Murpheys many laws that any second car will play up as soon as you get it. These are very minor dramas and easily fixed. You will learn to love it, trust me
    Oct 2002
    Melbourne Victoria
    11,798
    I endorse Haakon's remarks, teething troubles are just that... I am keeping at leats four Fuego's on the road and the gear linkages are something that I do on a
    nice day - doesn't take long and most times I have a spare set of bushes purchased from Ken Bailey at Caravelle, and of course I keep all spares, & bits that I glean from Pick-a-part wreckers.
    Usually you can swap parts around on the linkage discarding worn parts, and with the nylon bushes AND a new rear rubber pivot bush, the whole thing comes up pretty well. I have only found one badly worn part at the rear of the box and was lucky enough to find a better one in my spares.
    The other thing is that you do find many Fuego's in the wreckers that have a lot of new or near new parts on them (Complete new exhaust systems) lights, mirrors, clutches, half shafts, water bottles, radiators and air con parts.
    Many of those owners had paid dearly for regular service in speciality shops, but gave up on the car when either the TRX tyres wore out or something they thought would be expensive to fix happenned.
    With a few spares, time, and energy and the ability to read a manual, there is not much that can't be fixed at a reasonable price on the Fuego and it is still a great driver's car..
    Ken
    Jan 2003
    Tasmania
    392
    Quote Originally Posted by Haakon
    Dont worry Haakon, I don't give up that easily, at least not with cars.
    Unintentially, it's become a bit of a tradition for me to buy cars with gear change problems. About two years ago I bought an automatic Magna who's gearbox seemingly had a mind of its own. After being told I needed the gearbox reconditioned, I stubbornly resisted and eventually traced the source of the fault to a faulty throttle position sensor. The quote from the local Mitsubishi dealer for this cheap little plastic rheostat was around $400 - sent shivers down my spine. Subsequently, a study of the Gregorys workshop manual taught me how test the condition of these sensors, so off I went to the wreckers with my multimeter in hand to search for a good one. $45 later and a couple of hours of fiddling around trying to fit the thing without removeing the carby, I had a Magna with a decent automatic. Trouble is, the engine went soon after, buts that's Astron 2.6's for you, or so I'm told. There was no way of getting the motor fixed without spending a lot of money so I let the car go for $200.
    As a result, the rusting but reliable R16TS was bought back into service while I searched for a replacement for the Magna. Along came a tidy and original 504 GL, which I now own, but guess what? .... the automatic died a few months into my ownership. After being told a manual conversion would set me back around $2000 and the prospect of fitting another dodgy second hand auto sent me into despair, a friend reminded me of the good work done by a crowd in Hobart called Automotive Automatics. I can assure all Tassie Froggers that Automotive Automatics are wonderfull people, good old fashioned tradesmen who take pride in their work and don't charge much. My 504 left there with a fully reconditioned box, including torque converter fitted, with a warranty, for just $980!. Apart from an initial adjustment required to the kickdown cable it's behaved like a Swiss watch ever since.
    Sorry for wandering off topic, but I'm just making the point about not giving up. Whenever I look at the Fuego it puts a smile on my dial, its just such a beautiful shape. And apart from the dodgy gearshift, the rest of the car is in good enough condition for me to want to persevere. And it's a blast to drive, especially around corners....
    Jan 2003
    Tasmania
    392
    Quote Originally Posted by Kenfuego
    Ken
    Ken,
    Which bushes are still available? I would really appreciate this info.
    Jan 2003
    Tasmania
    392
    Offer much appreciated Haakon. However, I've allready asked Dave C. to investigate and quote on refurbishing an old one using new substitute bits. Dave has been very good to me over the two or three years that I've been dealing with him, giving me lots of advice over the phone which he has never charged for, and parts prices which are always reasonable and sometimes ridiculously cheap, so I feel that I should give him the oportunity to sell me some labour this time - which is where most mechanics make their living. But if it all falls through, there's every chance you'll hear from me...
    Let's stick together so we can keep more of these lovely cars on the road.
    May 2002
    canberra...
    8,752
    Quote Originally Posted by frogs4ever
    Sounds like a plan!! And I agree with your comments re. Dave - very nice bloke who deserves the loyalty.
    Oct 2002
    Melbourne Victoria
    11,798
    Hopefully this
    is the parts #'s at Caravelle, I cpoed them from Kens 2002 Catalogue - note that not all parts are in stock depending upon deliveries he gets in.
    M1290 7700703140 Gear shift bush (140)
    M1300-7700692252 Gear shift bush (252)
    M1310-7700685274 Gear shift bush (274)
    M1320-7700689713 Gear shift bush (713)
    M1335- 7700682544 Gear shift knob (leather covered)
    I usually just ask Ken to put a set together when he has a shipment in. Most times he has at least one set on hand, but if demand has been up, then you may have to wait for the next lot of imported parts to land. For that reason I usually order an extra set when they become available.
    I have one car that needs a set put in, (my spare silver 85 Fuego) but so far I have not had the time. (too much to do on my son and daughters cars!!)
    Hope this helps, - and of course I also endorse Daves work and help as a clubman and Renault expert, he does more than most to keep Renaults on the road where they should be.
    Ken
    Jan 2003
    Tasmania
    392
    Ken,
    Do you know whether those bushes listed above include replacement nylon/rubber inserts for those little ball joint thingies?
    Frogs.
