95 Laguna Rxe - Moving O/s Any Offer Considered
Results 1 to 2 of 2
    Jan 2005
    2
    Default 95 Laguna RXE (2.0l 4cylinder Green) - Moving 0/s Must Sell
    ABSOLUTE BARGAIN !!!
    1995 Renault Laguna RXE (2.0l, 4 cylinder, Brooklands Green)
    (SEE BELOW FOR FULL DETAILS)
    MOVING OVERSEAS IN 10 DAYS => URGENT SALE !!!
    ANY OFFER CONSIDERED !!!
    A great car with low kms and in excellent condition throughout.
    Sad to loose her but moving overseas so looking for a quick sale $6500 ono.
    Tom
    Mobile 0425 234 249
    Email [email protected]
    FULL DETAILS FOR MODEL
    {from http://www.carsales.com.au}
    Introduction
    A new model that has had substantial sales success in Europe is released onto the Australian market. Currently being built in two factories, Sandouville in France where the vehicles for the Australian market will be sourced, and Palencia in Spain. Over 90% of all components are recyclable and the Laguna is manufactured without the use of cadmium, asbestos or CFC gases. Highly recyclable polypropylene has been used extensively for major plastic components.
    Exterior
    Designed under the guidance of Renault's Patrick le Quement, the looks of the new Laguna immediately link with the 19 series in its current styling. Wrap over bonnet runs forward with a central extended portion framing the Renault corporate embleum. The forward and sloping windscreen runs into a roofline that remains high over the rear passenger's area. Front airdam has wide horizontal opening with fog lamps set to the outside. Wide black bump strip finishes off the body coloured bumper. Black lower airdam extension is fitted at the front and has air intake holes at either end. Exterior mirrors are body colour and door handles are finished in black. Body strength was enhanced at the design stage by using a one piece side body panel section. The rear glass is bonded to its frame, also adding strength to the vehicle's safety shell. Plain body colours are: Etruscan Red, Atlantis Blue, Glacier White, Midnight Blue and Persian Red. Metallic finish paints are: Adriatic Blue, Iceberg Silver, Brooklands Green, Aquitaine Silver, and Xerus Grey. Pearl finish paints are: Black and Bayeux Violet.
    Interior
    The Laguna has been designed to meet future regulatory criteria. It exceeds the 1996 European standard for interior noise, set at a level of 74db. The car also meets the voluntary standard set for recycling to come into effect in the year 2002. Dash has a rounded binnacle housing the instrument cluster. Centre control panel has displays for the time and ambient temperature at one level while the climate control system displays the set temperature in a mid level display panel. Audio system is located below the heater controls. Interior has a rounded styling theme with door mounted air vents and separate window demister vents. Front seats have deep bolsters in a sports style with the seat centre panels matching the door cloth inserts. Centre console lid/armrest is cloth covered. Rear seat continues with the now traditional Renault 60/40 split fold rear seat and has a centre armrest. Seats have an antisubmarining feature as part of the overall safety package. Immobiliser system is standard on all models and is an infra-red controlled central locking unit. Door locks are the free rolling type that will not operate for any foreign key or object. A further security measure is the fitting of an armoured jacket to the starter motor to prevent drilling or other tampering by thieves.
    Engine description Four cylinder, belt-driven SOHC, two valves per cylinder, cast iron block with cross-flow alloy head.
    Capacity (cm3) 1998
    Cylinders 4
    Valves per cylinder 2
    Engine orientation Transverse
    Head material Aluminium alloy
    Block material Cast-iron
    Configuration In-line
    Engine location Front
    Valve train SOHC
    Compression ratio 9.8:1
    Maximum torque 168Nm @ 3500rpm (DIN)
    Maximum power 83kW @ 5250rpm (DIN)
    Induction system Electronic port fuel injection
    Fuel type 91 RON ULP
    City 10.5
    Highway 6.4
    Fuel tank capacity (litres) 66
    Transmission description 5 speed man
    Final drive location Front
    Steering description Power assisted rack and pinion.
    Turning circle - between kerbs (metres) 10.8m
    Front brake description Ventilated discs
    Rear brake description Discs
    Rim material Alloy
    Front tyre description 185/65 HR14
    Rear tyre description 185/65 HR14
    Front rim description 5.5Jx14
    Rear rim description 5.5Jx14
    Length (mm) 4508
    GVM (kg) 1850
    Shoulder room - second row/rear (mm) 1396mm
    Body construction Monocoque
    Seating capacity 5
    Hip room - second row/rear (mm) 1465mm
    Hip room - front (mm) 1476mm
    Shoulder room - front (mm) 1425mm
    Kerb mass (kg) 1300
    Height (mm) 1433
    Wheelbase (mm) 2670
    Track - rear (mm) 1456
    Track - front (mm) 1480
    Width (mm) 1752
    Luggage capacity - seat up (litres) 452
    Luggage capacity - seat down (litres) 884
    Towing capacity - with brakes (kg) 1100kg
    Towing capacity - without brakes (kg) 620kg
    Maximum speed (km/h) 200km/h
    Anti-lock brakes (ABS)
    Driver's airbag
    Front passenger seat belt pretensioners
    Centre second row/rear lap/sash belt
    Height adjustable front seat belts
    Immobiliser
    Power steering
    Central locking
    Reach adjustable steering
    Remote central locking
    Electric windows
    Electric mirrors
    Air conditioning
    Climate control
    Driver's footrest
    Cloth trim
    Sunvisors
    Fully lined boot/luggage area
    Remote fuel filler release
    60:40 split fold second row/rear seat
    Split fold second row/rear seat
    Second row/rear headrests
    Front head restraints, height adjustable
    Second row/rear seat centre armrest
    Driver's seat - lumbar adjustment
    Manual driver's seat height adjustment
    Driver's seat - manual adjustment
    Front headrests
    Door pockets, front
    Glovebox
    Map lights
    Luggage/cargo compartment light/s
    Interior dome light
    Trip computer
    Digital clock
    Tachometer
    Warning lamp - low fuel
    Temperature gauge
    Fuel gauge, constant indication
    External temperature indicator
    Intermittent wipers
    Rear wash/wipe
    Rear window demister
    Body coloured bumpers
    Rear fog lamp
    Front fog lights
    Side protection mould
    Exterior mirrors, body coloured
    AM/FM radio
    Cassette player
    Electronic tune audio
    Security coded audio system
    Number of speakers 6
    Roof mounted aerial
    Member leigh's Avatar
    Ballarat
    74
    Quote Originally Posted by claphat
    Sad to loose her but moving overseas so looking for a quick sale $7000 ono.
    Tom
    Mobile 0425 234 249
    may need to include more info and put on for sale forum if u haven't done so already
