Nut size?
Thread: Nut size?
    Fellow Frogger! R17G's Avatar
    Gold Coast
    329
    Default Nut size?
    Thought that might get your attention.
    Anyone know offhand the size of the large nut at the end of the steering rack on a R17? Ie the one next to the rubber bellows where the eyelet screws in for the steering arm.
    My adjustable does not fit and I don't want to buy the wrong size (or several sizes).
    cheers
    A Gordini is still a GORDINI!!!
    1000+ Posts BogMaster's Avatar
    Canberra,act,australia
    1,457
    Quote Originally Posted by R17G
    cheers
    I always used a big shifter for that. If you can't get a size here, which would surprise me, try measuring it with callipers,
    Woo Hoo Honi ko'u 'elemu (Hawaiian)
    6,283
    I used a 15" shifter on mine. I think it was 36mm, but don't quote me. Yes, I know that's of no use.
    Edit: this SHOULD be of use. I just measured my spare rack in the shed with a vernier and it is 36.3mm across flats. I assume this is meant to be 36mm. That's an R12 rack, but it's the same I think.
    Stuey
    2003 PEUGEOT 206 GTi
    Nov 2002
    Yarrabilba, Queensland
    2,756
    Craig,
    ARe you going to get a spanner or buy a socket. I bought a 1/2 drive 36mm socket from a place out at Rocklea. I didn't want to have to go buy a 3/4 drive set for one socket. Let me know if you want one and I will pick you up one and get it to you.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Gold Coast
    329
    No thanks Chris I was after a spanner.
    Thanks Stuey!
