Two new racecars in NZ - Page 27
Page 27 of 28 First ... 17232425262728 Last
Results 651 to 675 of 696
Like Tree309Likes
Thread: Two new racecars in NZ
  1. #651
    11,107
    Wow, that is blown alright!! Out of interest, how far proud of the block face are the sleeves? Always an interesting question, for me at least. Sump debris is fantastic! Bad luck.
    I've had two attempts at a heat shield for the alternator on my Citroen CX and both have failed completely due to cracking under vibration and disappeared completely. The mount for my cruise control receiver near the magnet on a driveshaft failed the same way. Tricky and shows I'm a geologist not an engineer!! I'm thinking I should make them lighter not heavier or very much heavier!
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
  2. #652
    1000+ Posts Frans's Avatar
    Auckland
    1,531
    So before all this happened and I was bored stiff I started playing with an oil pump. I came up with a plan to make a high volume pump easily as you should know by now that it is hard for me to buy something that I can make. The dental floss budget you know.
    I came up with this prototype. Sacrifice one free wheel gear and cut it in two. I increased the one by 10mm and the other by 12 mm to get an idea. I will use an aluminium spacer plate of 10 mm or 12 mm as you can get that in a standard thickness and then the pickup will bolt onto the bottom. Then a plan will be made to shorten the pickup or I can use a different one because those pickups came in a few lengths as the sump depth varied over the years.
    The above photo shows the 10 mm addition which is connected by recessed screws.
    The above photo shows the other free wheel gear that will go in back to front so that the connection screws does not actually do a lot but that the gears actually drive themselves.
    The above photo shows the protrusion, one of 10 mm and the other of 12 mm and that is where the spacer will be.
    The above photo shows the recessed screws holding them intact.
    So that was my mouth full of what happened here lately and answering Henry's question of "how did it go?"
    Regards, Frans
    JohnW and bowie like this.
    Old enough to know better
    Young enough to do it anyway.
  3. #653
    Oct 2014
    Windsor 2756 NSW Australia
    626
    I know its not nice to think about but when you had the sump off did you see anything unusual with the bearings? the oil temp still seems high after you fixed the windage tray issues, it could be more than just the cooler location.
  4. #654
    Auckland
    1,531
    JohnW The sleeve protrusion is .004" plus the little ridge that I cut in another .004".
    Bustamif.... checked big ends and mains and they where all okay. The cooler location is on top of the gearbox crossmember where I am sure it is useless for getting any airflow. All it does now is increase oil volume. Me and Ross had alook when it was on his hoist and there is a way of fabricating a type of funnel to scoop air and sort off compress it and the feed it to the cooler. One will have to be careful not to make the scoop too low as it might get damaged with an off.
    Frans.
  5. #655
    11,107
    Thanks Frans. Interesting. I've just bolted a Dauphine Gordini head down (annealed copper base rings of course) and had them all 6-8 thou before tightening. I reckon that will leave 2-4 thou protrusion after the copper rings squeeze the 4 thou I've measured. Geckoeng reckons 8 thou, which is therefore, after squish, the same as your 4 thou. Am I paranoid about this? Probably!
    That's quite a head gasket of yours....
  6. #656
    Auckland
    1,531
    Some useless info for those interested.
    I made a list of mods or specs that I have done on the race car. Started in the front and worked the way to the back from what I can remember but the list will be about 99% complete.
    Frans.
    Shoji, bowie and keith mcelroy like this.
  7. #657
    11,107
    Hi Frans,
    Quite a list!
    That'd be HDPE tube not PVC I think. "Black poly" is it not? PVC has a low softening temperature.
  8. #658
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    489
    Frans,
    You left out that super effective exhaust system. Are the suspension coils not shortened?
    What front anti roll bar are you using?
    I know your list is just the obvious basics, because I know there are many more detailed mods involved, some are: window glass-to- perspex lightening
    plus other body lightening, negative camber inducing off-centre bushes, shorter rear axle limit straps(chains), etc, etc. I think it will take a long time to recall / record all the not so obvious mods, some of which have taken considerable thought and effort to apply. And I think it's great!
    Henry
    JohnW and R8 Dream like this.
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
  9. #659
    654
    Quote Originally Posted by rubyalpine View Post
    Frans,
    Henry
    Yes...the devil is in the detail!
  10. #660
    Fellow Frogger! alpinesau's Avatar
    290
    Frans,
    Have you considered using the later type oil pumps fitted to R5s? Jeff Bee used one in his big-bore R1135 motor to good effect.
    Is your current oil pump a Gordini pump which has the longer gear set over a standard R8?
    If not, these 2 off the shelf items may help you, and be whole lot less work than what you are considering. (I know, you like doing it yourself at the lowest possible cost)
    1970 R8 Gordini R1135
    2005 Megane 225 Cup
    2008 Clio X85 Cup Racer
    2014 Megane RS275 Trophy R
    2015 Koleos Expression
  11. #661
    Auckland
    1,531
    Hi Alpinesau,
    I wasn't aware of the R5 pumps. Do they have higher volume pumps fitted as standard?
    My current pump is standard R8 pump ie. the short gears and yes I am aware of the G pumps higher volume.The G pump gears are 6mm longer and my idea was to exceed this and do the 10mm or 12mm so that it will have plenty volume in hand and as an experiment as well.
    Henry, You are correct in all those points and to be honest, I haven't even thought of it. Yes the list will be much longer although the anti-roll bar is standard
    Regards, Frans.
  12. #662
    290
    Looks like the R5 Alpine & R5A Turbo have a similar set-up to the R8, but are bigger. (Refer the details on the Meca-Parts catalogue.) There are 2 or 3 options.
    Ignore the photo which is from an R16 engine.
    Attached Thumbnails Attached Thumbnails Two new racecars in NZ-oil-pump-gears.jpg
    JohnW likes this.
    2005 Megane 225 Cup
  13. #663
    Nov 2011
    Norway
    60
    If there is differences in oil pump capacity among the cleon powered R5 models I would think the R5 gt turbo(120bhp) would be the one to check out.
  14. #664
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    397
    Hi Alpinesau,
    Regards, Frans.
    Ray.....
    JohnW likes this.
    1969 Alpine A110
  15. #665
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,166
    Quote Originally Posted by nauli View Post
    Ray.....
    For your engine Nauli?
    I just had a look at your pump this morning. it's the smaller one if i'm not mistaken
    ďListen very carefully, I shall say this only once.Ē Cheers. John
  16. #666
    Oct 2017
    Perth, WA
    397
    Quote Originally Posted by Shoji View Post
    Not sure John...I leave it up to the Geckomeister!
    1969 Alpine A110
  17. #667
    Auckland
    1,531
    Hi All,
    Went racing yesterday!!
    We raced at the Pukekohe track which should be known to most of you petrol heads. This track had a small change a few years ago. Because of the very long straight, a kink was introduced in the straight to slow cars down. The other times I raced here we raced on the layout that included the kink, but yesterday we raced on the old layout using the long straight. This allowed me to use max top end with my car. With my new settings on the MegaJolt I managed to get the shift lights to come on in top gear down that long straight.
    So, I calculated my top speed and it is hard to believe. If it is correct, I am very chuffed. Please check my calcs and say where I went wrong, if I did.
    Rear tyre size: Toyo R888 185/65x13
    I used 1:1 ratio for top gear.
    Diff ratio of 16TS= 3.77:1
    Engine rpm =7200.
    My circumference worked out to 1793mm, and according to Google calculator at my engine rpm of 7200 it topped out at 205 kmh.
    Regards, Frans.
    bowie, FIVEDOOR, jaahn and 2 others like this.
  18. #668
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,484
    Fantastic!
    Frans likes this.
  19. #669
    11,107
    Frans, I haven't checked the calculations but I'd believe it of you and the car!
    Best wishes to you and yours for 2019.
    Frans likes this.
  20. #670
    654
    Hi All,
    Engine rpm =7200.
    Regards, Frans.
    In in a previous post I noted that I did a top speed of 142kmh down the main straight of Sandown, but rev limited at 5000 ( was running in my engine). I am running also a R16 strong box.
    According, if I could run at 7200rpm, then my theoretical top speed would be using linear extrapolation: 142/5000 X 7200 = 204.48kmh!
    So I believe you are on the money Frans!
    Angelo
    Frans and JohnW like this.
  21. #671
    9,167
    Why not get a GPS and take out the vagaries of the input data?
    Short of that, I would measure the actual circumference of the wheel (mark wheel and road, roll one full turn with the car, mark road, measure) because I suspect that is the most uncertain of all.
    Either way, even approaching 200km/h in a R8 is a performance in itself.
    I have seen 200km/h in a few cars and it's not always comfortable. I remember well 150km/h in my dad's R12 and that was pretty focusing to put it that way.
    jaahn and JohnW like this.
    ACHTUNG ALLES LOOKENPEEPERS
  22. #672
    Auckland
    1,531
    Agree that a GPS can do it. I'll have to re-program the Megajolt so that I have an output LED come on at 4000 rpm, check the speed on the motorway and then calculate from there what 7200 will give me because I don't know whenever we will run on that track configuration again to it actually achieve that speed. The wheel circumference was done exactly as you suggested. That is where I got my 1793mm from. I am positive about the 7200 because I don't think the MegaJolt will be out at all. It is not like a rev counter that could read a little high or a little low.
    In the one heat I easily outran a V6 Ford Telstar. That is with the 2500 V6 engine. TX5? But I think it was a standard engine with only a lightened body. I must admit that it was the first car that outbraked me. I went to talk to the owner afterwards and noted that he had massive Wilwoods on there and he said that they are setting the car up for endurance racing.
    That speed was sort of uncomfortable but I weren't allowed to go slower, we were racing.
    In this configuration it becomes a big horsepower track. I noticed it because in my Youtube videos you can see me overtake an orange TVR powered by the 3000cc Ford Essex V6 regularly. On Monday it stayed ahead and I couldn't overtake it.
    I will still see how the incar cam videos came out and post it here.
    Thanks Angelo, Now I AM chuffed with the blue beast!!
    Regards, Frans.
  23. #673
    Fellow Frogger! potentz's Avatar
    Jul 2011
    adelaide australia
    310
    Man!l would LOVE to drive your beastie on track.
  24. #674
    9,167
    Regards, Frans.
    I don't think you are out or if you are not by much. Would be interesting to have it recorded on telemetry/GPS just for giggles.
    And posterity!
  25. #675
    Fellow Frogger! keith mcelroy's Avatar
    Sep 2004
    ballarat
    249
    Absolutely brilliant! As an engineer and driver.
    Please expand on " slightly uncomfortable" driving it at over 200 kph. I have had my Alpine kitted R8G rally car flat stick on the Nullarbor. But not that quick. Just how floaty was it ?
    Cheers Keith
