That rear washer! Where is it?
Results 1 to 7 of 7
    Dec 2004
    16
    Icon5 That rear washer! Where is it?
    Okay this is probably a dumb question - but does anyone know where the rear window washer reservoir lives on a 2003 Scenic??
    No it's not in the manual... suggesting that perhaps it runs from the front washer reservoir.
    If this is the case then since the pump works but no liquid spits-out now I have the new problem of how do you un-block the tube presumably running halfway across the car insides???
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    hey crash, check the hatch of the scenic... there should be a reserve somewhere on one of the sides of the inside hatch.
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    Fellow Frogger! biologist's Avatar
    867
    Quote Originally Posted by pugjet
    Your probably right pugjet. I've no idea myself, but one
    or two cars I've come across the rear washer is supplied
    from the front tank but the takeup for the rear washer
    is higher than the front so it "runs dry" before the front
    washers do. Not sure why they do this but I did find it
    useful in that it reminded me to fill the reservior.
    Biologist
    A
    one Megane Family
    NSW
    4,918
    Not a dumb question at all i guess as i have a C3 and was wondering the same thing long ago....
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    These should help...
    Attached Thumbnails Attached Thumbnails That rear washer! Where is it?-washer1.jpg   That rear washer! Where is it?-washer2.jpg
    867
    OOOh, then you may have a blockage in the line.
    Check near the tank and look for a filter (hopefully)
    or else if you have a mate with a compressor and one of
    those little gun jobbies which blasts air out of a tube
    with a small hole and try pushing air backwards down
    the tubing and clear the blockage. Blowing it in the
    direction of the water flow may just make the sit worse
    best of luck,
    Biologist
    A
    one Megane Family
    May 2002
    Enruoblem
    2,098
    ahhh... sorry for the bad advice... had a squizz of a family friend's scenic some time back and i thought i saw a rear reserviour.
    thanks europa.
    current frogs :
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
