core plugs
Thread: core plugs
    Feb 2005
    UK
    2
    Default core plugs
    Hi, I have a UK based Renault Clio, with 1.2l type 'e' engine. It is leaking coolant from one of the core plugs in the cylinder head. The plug is tiny (1-2 cm). Anyone any ideas if you can buy these little rascals, and any ideas on how you replace them?
    Ta,
    Jim.
    Perth Western Australia
    2,705
    Default core plugs
    Quote Originally Posted by the tinker
    Ta,
    Jim.
    Hello Jim,
    My memory tells me that the small core plugs you mention were fitted to the PRV6 water pump housing. Your Renault parts man might find them in his Renault 25 V6 parts book. Just thought of something, check the V6 cylinder head on the exhaust side, I think they may have been fitted there.
    To remove plug, punch a small hole in it and lever out without damaging the casting.
    To refit, smear gasket cement* on the plug and tap back into 'ole.
    *Don't use Silastic or similar.
    "Jim"? You wouldn't be Count Jim Moriarty of the "Fifth Foot and Mouth" who one time had a dalliance with "Spotty Minnie Banister"?
    12,283
    they are an odd size in the PRV6 heads
    27mm from memory
    i can check but it's dark outside and it's wet and well i'm very nice and comfy right now
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Why not pop down to your local dealer and purchase it as a spare part?
    If you supply oval plate details, I might even be able to give you a part number.
    2,705
    Default Core plugs.
    27mm from memory
    "Rambo,
    Good memory, my Peugeot parts manual says 27mm for the V6 exh. side.
    The core plug I mentioned isn't shown on the Pug V6 water pump, it has a spout instead for connecting to the inlet manifold.
    The injection V6 water pump didn't have this spout. Replaced by plug?
    Jim, wouldn't your local "Halfords" or "Demon Tweaks" be of help?
    6,665
    Most core plugs can be bought as generics - for example, I bought the tiny ones for the R12 inlet manifold from Repco in brass for a couple of bucks. These might even be the same! They're about 15mm from bad memory.
    Jim as suggested, Halfords or similar motor factors over there could help I'm sure. You only need the size in mm. Pull it out and take it in - they'll measure it with a vernier caliper.
    Stuey
    2003 PEUGEOT 206 GTi
