R10 boot lid seal.
    Nov 2002
    Yarrabilba, Queensland
    2,759
    Default R10 boot lid seal.
    I have misplaced(read tossed out ) the boot lid seal that runs along the top pf the radiator cowl below the boot lid of my R10.
    Has anyone bought one of these recently? Who would stock one?
    Slow restoration speeding up slightly, but I decided to dress up the gauges the other day, may-be I should have left well enough alone, I dropped one, the speedo, and cracked the lens. It's only a short crack but it's there. Damm
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Roselands
    35
    Default Bootlid seal
    Try Clark Rubber, they can get R10 and Dauphine rubbers for most of the car, they have a catalogue, I believe they get the rubbers from Spectrum Rubber here in Sydney.
    I hope this helps.
    Roger
    Nov 2002
    2,759
    Thanks Roger,
    I had to call Caravelle about something else today, so i asked and they said to try someone like that or Rare Spares, as the rubber is fairly common type.
    Tried to order a master cylinder kit for the R10(20.6mm) but they are out of stock, and a long way off. Found a place here who will do sleeve/kit for under $120.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Sep 2004
    Tamworth UK
    624
    Default R10 Master cylinder
    Quote Originally Posted by HONG KONG PUGGY
    Thanks Roger,
    I have found a guy here in NZ with new old stock of these, want me to investigate?
    Nov 2002
    2,759
    Quote Originally Posted by kiwia110
    Kiwia,
    That would be great. Firstly I'd be after a 20.6mm kit, & outer boot for the end. Find out if he has stock of the 22mm kits also would be good. I am considering having the m/c rebored and a larger sleeve inserted. Find out a price, and I'll get you to post me a kit or 2 if available.
    Cheers, Chris.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
