Faulty Fuego rev counters
Results 1 to 8 of 8
    Mar 2005
    Hamilton New Zealand
    11
    Default Faulty Fuego rev counters
    And a great big introductory Bonjoooor from over the ditch.
    I have recently supplemented my long-lasting Phase I Espace with a Fuego or 6.
    The common fault so far is that the tachometers are all faulty in one way or another. All the needles (incl. sppedo) are a bit distorted or cracked, and therfore possibly unbalanced, and they either don't read or are wildly out.
    Is this a known Fuego fault? I generally like to have an accurate tacho.
    Mar 2005
    tasmania
    7
    Default fix it for tacho
    Yes good old fuego needles were not built for our stunning climates
    heres a fix it
    unscrew the dash assembly(its pretty easy)you will need to break the seal on the screen of the instruments but this shouldnt be a problem
    pull off the needles gently with pliers or some such thing and replace them with some similar needles from a similar european car (I used a fiat 132)
    I calibrated them by setting them as close to zero as I could and finished by following a friend at set speeds and adjusting accordingly,not rocket science but better than no instruments!
    Oct 2002
    Melbourne Victoria
    12,588
    Default Fuego - rev counters
    The Fuego tacho is driven off the same speedo cable and in any cable system most of the inconsistencies come from variations as the cable dries or slight kinks develop - generally careful lubrication of the speedo cable will assist its consistency and accuracy.
    In my view if you really do need to rely on an accurate tachometer then best to rig an electronic accessory timed from the engine revolutions, I am sure that there are other technical people who have done this conversion and willing to help.
    Regards and enjoy the Fuego.
    Ken
    Moderator vivid's Avatar
    parallel 43 south
    1,900
    Quote Originally Posted by simonfuego
    Thats fine for the speedo, following a friend. I did the same.
    I used a set of commodore needles in mine, and they work fine, (same size and amount of plastic) so you should be able to replace them from all sorts of makes.
    David.
    Powered by high grade French plutonium.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Quote Originally Posted by Kenfuego
    Ken
    the tacho is electronic - not many cable driven tachos in the world (I can only think of early NSU Ro80 as an example)
    VK Commonbore needles are the go for replacement - the actual electronics rarely give trouble.
    Mar 2005
    11
    Default Thanks for the responses
    Thanks to all of you with practical knowledge of these cars.
    I took the instrument panel out of my donormobile and played around with the needles. Perhaps I shouldn't be annoyed that the speedo and tacho needles take different diameter shafts ...
    I tried the needles out of a lying-around Nissan unit, but they weren't ideal, so I'll chat to my wrecker friend and see what's lying around, with a particular eye out for the magic VK ones. That's a total of probably 8 or 10 needed!
    I managed to wire up an electronic signal to test the tacho, so calibration won't be a big problem to me.
    Oct 2002
    Melbourne Victoria
    12,588
    Default Mind blip!
    Quote Originally Posted by Haakon
    Booger - thanks Haakon, had a "senior mind blip there", of course works from the ignition module and timed from the Top dead sensor lead activated from the flywheel, geez I've pulled enough of them apart!.
    I tend not to worry about the rev counter too much but like to keep the speedo as accurate as possible!!
    I suppose the accuracy (tachometer) can be effected by the old cabling and connections (voltage drop) on the Fuego.
    Ken old and
    Member GunnaWanna's Avatar
    49
    If u want to spend some moeny on it I suggest Ringwood speedos, in )u guessed it) RINGWOOD!!!
    They'll replace the needles AND recalibrate the speedo for you.
    Its not that cheap but atleast you know your speedos is accurate. I'd suggest replacing the cable at the same time.
    para un auto de rapido fuego
