RSC lights up around corners!
Results 1 to 12 of 12
    Perth/Australia
    37
    Default RSC lights up around corners!
    On a couple of occassions now during extreme cornering (well, not too extreme i.e. rear end hadnt swung out yet) the "stop" and the handbrake lights have lit up periodically and then gone off after exiting the corner.
    Anybody had this?
    Perhaps an RSC's way of giving alternatives whilst navigating through the corner i.e. "stop" you idiot youre going to fast or perhaps throw the handbrake and make this corner slightly more exciting?
    Fellow Frogger! Reno's Avatar
    1,260
    i have read this before
    something to do with brake fluid. either low or should be topped up or changed.
    Member ParanoidAndroid's Avatar
    111
    Yeah its common. Mine used to do it and I made sure the airbag wiring under the seat was secure and it stopped doing it. Have a quick look under the drivers seat and make sure its plugged in properly.
    Gold Coast, Queensland
    102
    This use dto happen on my old Swift GTi, when cornering hard the handbrake would lift up a little causing the handbrake light to come on up on the HUD, perhaps ur having the same problem with ur clio?
    JoJo
    1,160
    yeah PaulD had this one... low Brake Fluid level... the question is... where did it go!
    Perth/Australia
    37
    Damn good question Nate!!!!! Considering i've just had the 40K service about 3 weeks ago!!!!!
    Fellow Frogger! biologist's Avatar
    867
    Quote Originally Posted by nate
    Check your brake pad wear, when they start to wear down, ie get thinner,
    the caliper pistons, and there are lots of them, move outwards drawing
    fluid out of the reserviour...
    Certainly got lots of options to check with this little problem though
    Biologist
    A
    one Megane Family
    NSW
    4,918
    Icon2
    I think this was just a Renault thing. Im sure my Renault 19 used to do that around some corners. (not that i was going that fast in that car though)...
    Sep 2003
    105
    It's a wiring fault. My brake fluid is as full as it can go, and the light still comes on during hard cornering.
    Feb 2003
    576
    Quote Originally Posted by danielsydney
    Or maybe you should have had it fixed Daniel. It shouldnt happen.
    2013 Grand Kangoo
    2011 Megane 3 RS
    2001 Clio Sport 172 (23/85)
    1997 Spider (No. 652)
    1988 5 GT Turbo Phase II
    1968 10
    Fellow Frogger! bigbadbyrnes's Avatar
    May 2004
    Alstonville (near Ballina) Far North NSW
    601
    had exactly the same thing happen to me heading up to Springbrook last weekend on the drive - stop and handbrake lights sort of flickering on then staying on for a tick, then flickering out as you ease off the throttle and straighten up out of the bend.
    Dont really think it could be brake fluid as I had my servce done not 500ks ago, albeit not from the $tealership. But it was the only 20,000km anyway.
    Any further advice? Is it unsafe to be driving hard if this problem is arising?
    '87 Camry 2.0ltr injected---------5min 11 sec
    '85 Charade turbo 700cc----------5min 06 sec RESPECT
    '99 GX Impreza 2.0ltr-------------5min 02 sec
    '99 WRX w/ hi-flo exhaust------4min 46 sec
    Byrnesy's 172---------------------- 4min 25 sec
    1,160
    Possible wiring under seat?
    check the connector under the driver & passenger seat... through that normally triggers the ABS light too...
    EDIT:
    oh, just remembered..
    Does your brake light come on early enough?
    i.e. as soon as you press the pedal?
    mine wasnt & sent the system into a little fit!
