Wiper switch swap for Gordini
    Fellow Frogger! R17G's Avatar
    Gold Coast
    329
    Default Wiper switch swap for Gordini
    Due to the fact that my variable wiper switch keeps braking the stalk off on my 17 Gordini, I have tried to fit a 2 speed off a TL. The connections on the back appear to be the same but when used they keep blowing fuses. I have tried 2 and both do this.
    Anyone have experience with these that can tell me why or how I can fit the 2 speed?
    Better yet anyone have a good variable switch that they don't want?
    A Gordini is still a GORDINI!!!
    Simon's Avatar
    6,172
    The 17G has a relay in there for the delay mechanism, as well as the variable speed control part, which the 17TL doesn't have so it may require a bit of bypassing to make the two speed switch work.
    1000+ Posts Europa's Avatar
    Jan 2002
    2,432
    Been there, tried that, doesn't work.
    To successfully "glue" your stalk, fibreglass resin is a great way to go.
    You could also investigate a hi-temp glues (Loctite may have something appropriate) - normal household glues (ie. Araldite) are OK but only up till about 40 degrees or so when they go soft, and the stalk falls off!
    Gold Coast
    329
    Thanks guys, I have tried good glue. I may have to look into the resin.
