Tapping Noise coming from engine
    Sydney Australia
    60
    Default Tapping Noise coming from engine in RSC
    When I'm sitting in Neutral with the engine idling, if I touch the accel when the revs come off idle there's a tapping noise coming from the engine.
    Is this normal?
    Fellow Frogger! storms_of_fate's Avatar
    Nov 2003
    367
    Is this when the car is still reasonably cold? can you describe a bit more? is it like sort of uneven engine speed? It should be normal if the car is cold. That sort of noise should be the oil pump working. Should smooth out after warming.
    Karl
    Sydney Australia
    60
    No, it's when the engine's up to normal operating temp, it doesn't idle smoothly either. The guy at the dealership said it's just the fact that they put a 2L engine into such a small car. It kinda burbles, is this not normal?
    As for the tapping, it's when the engines hot too...I can only hear it when the revs are just over idle.
    Sydney Australia
    60
    Anyone? The engine idle's pretty rough most of the time, I mean it's quiet, just that you can feel the engine through the car..
    JO3
    JO3 is offline
    SYD
    18
    if u're implying that the inside of the car vibrates a little due to the engine...
    i think it's normal..
    cos mine does that and the renault workshop said it was because of the sports cam they have in the rsc..
    at least thats what i was told...
    and i think u will also notice the muffler "sputerring" constantly...
    hope that helps...
    1,160
    Fresh oil made mine sing like a bee... but after 3,000k's its a little grumpy in the morns...
    Also heard that due to ADR, the engine runs lean for a little to heat up the Cat converter... ?
    as for the tapping noise... hmmm
    Check engine mounts (its a common one)
    Not a 4,000rpm rattle? (perhaps a loose baffle?)
    other than that, come for a run with us, say hi & we can nod our heads & point at your engine
    (next one is tomorrow nite!)
    http://www.ozrenaultsport.tk
