Diff Setup for R16
    Fellow Frogger! Ross's Avatar
    Auckland NZ
    380
    Default Diff Setup for R16
    Im currently in the final stages of fitting R16 internals into R8 casings.
    What I need is the measurement between the diff bearing centre and the pinion face.
    Anyone got a R16 workshop manual, im sure it would have this measurement.
    Ross
    Simon's Avatar
    6,161
    Which type no of 16 gearbox did the CW&P come from? As there are several different measurements depending on the type of gearbox.
    Auckland NZ
    380
    Sorry dont have gearbox number
    I was just a standard 4 speed 16TS.
    Ross
    Simon's Avatar
    6,161
    There should be a type number and index number engraved on the face of the pinion or on the periphery of the crown wheel, like 336-xx.
    If it is a 16TS box, it should be a pinion distance of 53mm.
    Pinion depth confirmed as 53mm.
    Auckland NZ
    380
    Thanks Simon
    I have all the special tools to do the measurement so hopefully all will go well
    Ross
