r 17 g /box
Thread: r 17 g /box
    melb vic australia
    172
    Default r 17 g /box
    can u put a standard r 17/15 box in a renault 12 without swapping much and if u do have to swap items what do u swap . the car has a 1.4 motor with early model g/box car is a 75 model with a 1.4 flywheel and clutch so what would i have to speed or is there no advantage to fitting a 17 /15 4 speed or is it better to fit a virage g/box to it please advise
    classic no plastic just lots metal but lots of fun
    Ipswich, Queensland.
    1,888
    The spiggot shaft and of course the bell housing need to be changed. An original 15/17 box should have a final drive ratio of 3.54, as opposed to the standard 12/1.4 ratio of 3.77. The very first 12s had a 4.125 ratio but are hard to find. The gear ratios have small changes, but all would be called wide ratio boxes.
    For normal use with a modded 1.4 the 3.77 works best for most activity. The taller 15/17 ratio is OK, but you need to travel at 120kph to reach the torque peak of the 1.4 in top.
    A friend has had the tall ratio and lightly modded 1.4 ( ported head, compression,cam) for many years and loves it, but the car spends most of its' time on the open road.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    melb vic australia
    172
    Default g /box
    so a 3.77 would be a virage g/box alan would that be rite as i do use this vehicle for a little competition work as well mainly sprints and hillclimbs
    1,888
    Yes, the Virage box has a 3.77 diff ratio.
